In advance thanks guys
2ndclasscitizen wrote:Fit a M10 X 30MM bolt into the hole through the cable mounting as shown to lock the gear leaver in to neutral.
Once the gear leaver is locked you then need to remove the 2 metal clips on each cable and then push forward the black plastic piece that the clip is holding on.
Adjust the cable, push the black plastic piece back again, replace the clip, take out the bolt and check the gears.
Have you also checked the bolt on the selector?
