mk6 fuel consumption jumbo
Re: mk6 fuel consumption jumbo
Postby madmart132 » Sun Mar 05, 2017 1:27 am
I am fairly sure even if you have the very low geared diff that you have another problem, I have a luton mk6 petrol with a 5.13 diff and i get 20+mpg (4.5 mpl ) ... and its a petrol .
My Jumbo is also a petrol with 5.13 axle and gets over 25 mpg ( 5.5 mpl ) obviously with my luton its not very fast but my Jumbo is and I drive it pretty quick as well I long ago gave up bothering with the diesels but I am guessing the pump is out a bit .
madmart132
Postby grandads_shed » Sun Mar 05, 2017 2:22 am
madmart132 wrote:I am fairly sure even if you have the very low geared diff that you have another problem, I have a luton mk6 petrol with a 5.13 diff and i get 20+mpg (4.5 mpl ) ... and its a petrol .
i agree i think i have a problem with it ,, it used to go over 20mpg , i will get the mot done first as its due next week, then get the codes read ,
grandads_shed
Postby grandads_shed » Wed Mar 22, 2017 12:13 am
grandads_shed wrote:
grandads_shed wrote:is yours a jumber 2,4 mk6 m8 ?
sorry typo, should be is yours a jumbo 2.4 mk6 :)
YEP THATS THE ONE M8 , opps caps .. very sluggish to say the least , 0 to 60 in 1 minute and 45 seconds ,, and no im not joking ,
grandads_shed
Postby bigsparks » Fri Mar 24, 2017 12:38 pm
Hi all
my fuel problem now,
used to get a consistent 27 mpg on the M/Home and runs around at full weight 3.400kg
but last runs now 18 ish / but seen traction control knob is on OFF been told its to be ON
seem logical to be off !! not lock up the diff if that what it does/
jacked it up and cycled switch not seem do anything to back axle and wheels ??
cheers all
bigsparks
Postby knobby1 » Fri Mar 24, 2017 9:01 pm
bigsparks wrote:Hi all
cheers all
Traction control..?? Didn't know Trannys had that...ABS and possibly ESP but not T/C..??
