by RPWC » Mon May 29, 2017 9:49 pm
I narrowed it down to the contact on the side door, as when I cleaned the contact, and sprayed the pins with wd40,it worked. It was ok for a few days, but been away and came to move it before,mwont lock again. Have removed loom plugs from the pin switch and contacts on the side door, no difference, is it worth taking the pin switch connector off the door? how do I get to it, as the door is nor accessible either closed or open, surely don't have to take the whole door off?
cheers Rich
