TDDi 2.4 injectors
TDDi 2.4 injectors
Postby rotory » Sun Feb 25, 2018 8:22 pm
Hi lads.
I own a 2.4 TDDi 125 rwd, it sounds like I have a leaking injector as I can hear a constant pht pht sound and I’m down on power.
Would anyone know what type of injector would be installed Bosch or Delphi etc and would they be steel or copper seals. Having difficulty locating new seals for TDDI.
Many thanks
Martin
2004 Mk6 TDDi, 2.4l, 125bhp, WF0AXXTTFA4B01902
rotory
Re: TDDi 2.4 injectors
Postby Mad Husky » Sun Feb 25, 2018 10:15 pm
Had a quick look on ebay appear to be copper.
Mad Husky
Postby ned » Sun Feb 25, 2018 10:38 pm
Mk6 injector washers are normally steel and come with the injectors, have you checked all boost pipes for splits. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby rotory » Sun Feb 25, 2018 11:19 pm
Thank you both for your replies.
I’ve taken the complete air system out, pipes/ intercooler/ egr/ manifold etc, blanked the EGR. Installed new EGR then the repeated pht sound. Hunting idle 750-850, should be 900.
So is it copper or steel washers ?. Can’t find the right ones.
Martin
rotory
Postby Burtie1 » Mon Feb 26, 2018 8:55 pm
I’ve recently taken my injectors out and the seals look to be made of steel
Burtie1
Postby rotory » Mon Feb 26, 2018 9:00 pm
Cheers Bertie,
Today I rang Bob Beck’s fuel injection company and they are supplying a set for me. I hope they are the correct ones.
Did you have any difficulty removing the injectors ?, and where did you get your new seals from ?.
Martin
rotory
