Paul N wrote:yes sorry its a 2004 high top transit 350 lwb 1998 cc , diesal, think mark 6
knobby1 wrote:Paul N wrote:yes sorry its a 2004 high top transit 350 lwb 1998 cc , diesal, think mark 6
Not the horrid Mk6 TDCi Is it..?? Does it have a TDCi badge on the grille and 125 on the door..??
rebuilder86 wrote:u bought a battery and that temporarily made things better.... ur alternator has likely failed.
I just experienced similar symptoms wiht a 1999 diesel 2.5 while the alternator was failing.
The turbo doesnt work when it happens and the fuel is controlled wrong aswell.
Paul N wrote:just been to garage and they've washed there hands of it but did say that alternator was fine as he checked to see that it is charging fine
Punto443 wrote:Easiest way to check engine type is look at the injectors, if they have electrical connectors then it’s tdci, if only a metal pipe, then tddi.
Or tell us your reg no.?
bambi mk 1 wrote:Punto443 wrote:Easiest way to check engine type is look at the injectors, if they have electrical connectors then it’s tdci, if only a metal pipe, then tddi.
If its a 350 fwd its more than likely a God forsaken Nedly van
Paul N wrote: did say that alternator was fine as he checked to see that it is charging fine
