65mm rwd nuts lolzzzz
big important business men like me and Ned haven't got room for the likes of those in our apple catchers
ned wrote:Yep gauge pressure but only when the loud pedal is in the carpet from the off, normal driving its about 20 psi and you can hear it dump pressure on gear changes at 20 - 23 psi with the cone filter, its eating its tyres though N
bigjohnthomas wrote:65mm rwd nuts lolzzzz
knobby1 wrote:ned wrote:Yep gauge pressure but only when the loud pedal is in the carpet from the off, normal driving its about 20 psi and you can hear it dump pressure on gear changes at 20 - 23 psi with the cone filter, its eating its tyres though N
WOW...29psi is a lot more than I would imagine....Mine's been well mapped with 170ps+ and boost is still only in the low-mid 20's..!
ned wrote:I can't have a re-map my gauge take off is just next to the turbo plus I have "tinkered" with the actuator I'll try and film the gauge. Don't forget your turbo is electronically controlled mine isn't. N
