limp mode ????
limp mode ????
Postby scottie » Sat Jun 23, 2018 6:20 pm
the other day i got a warning light on the dash, the cog with the exclamation mark in it
van had to throttle response, pulled over and turned it of and restarted it and it was fine, its done it a couple more times in the last week
any ideas ?
will get it plugged in when i get a chance
scottie
Re: limp mode ????
Postby knobby1 » Sat Jun 23, 2018 11:31 pm
scottie wrote:the other day i got a warning light on the dash, the cog with the exclamation mark in it
van had to throttle response, pulled over and turned it of and restarted it and it was fine, its done it a couple more times in the last week.....any ideas ? will get it plugged in when i get a chance
Would really help if you told us what van you had....guessing can lead to incorrect information.
And yes, you'll need to get the codes read, otherwise it becomesan expensive guessing game.
Re: limp mode ????
Postby scottie » Mon Jun 25, 2018 5:18 pm
only done this once in the last 2 days, today i pulled over and let it tickover for a min, the revs wouldnt go about 2500 but has no power to pull the van, switched it of and restarted and it was fine again, drove great just like it has for the last few years
plugged it in and got these codes
P062b internal control module fuel injector control performance circuit below threshold pending DTC
P115a low fuel level forced limited power not current DTC
P404 EGR (ive got the EGR blanked)
P121c cylinder balance injector leaking not current DTC
scottie
Re: limp mode ????
Postby Altransit » Mon Jun 25, 2018 5:22 pm
knobby1 wrote:Would really help if you told us what van you had....guessing can lead to incorrect information.
Re: limp mode ????
Postby scottie » Mon Jun 25, 2018 5:32 pm
oops :-) its a 2007 2.2 FWD
also noticed anytime it does it im just about to pull away from lights etc
scottie
