Having chased my self up my own arse with my 2010 Jumbos' not starting issue , the only thing I haven't now swapped/replaced several times is the ECU. What do I need to have Part No wise to match? Present one is AC11 - 12A650 - CB.
At cranking, the rail pressure comes up, it fires 1 cylinder, rail pressure falls on it's arse, couple of turns for the pressure to come back up, fires 1 cylinder, rail pressure drops out again. No fault codes other than stuff being disconnected and over cranking. Fires and runs instantly all the time it's getting a bit of sniff. As far as IDS is concerned there appears nothing wrong other than not holding rail pressure - I'm no expert with IDS so not sure what I'm looking at to be honest.
The only other thing attached to the engine I haven't done is change the main vehicle loom, but surely that would show a code?
If I track down a suitable ECU, what is involved with pairing it with immobiliser, BCM, ABS, etc?
Jim
