by tranmx2 » Thu Apr 04, 2024 1:02 am
The throttle and accelerator are different units.
From that which I have read of it and concluded.
The throttle position is related to the EGR position. As the EGR opens the throttle closes.
Activation of the EGR is via the PCM which looks at engine rpm, vehicle speed, accelerator position, inlet air temp, manifold air pressure, DPF temps and presure, turbo vane posiion, engine coolant temp, engine oil temp, plus maybe some more.
The EGR is opened for example when the engine is under a light load - cruising on a motorway.
92.94% - is that open or closed what is 100%?
The image shows DRPMIS 840 so likely the actual rpm is about the same - as the engine is not under any load the 92.94% could be the throttle open.
As the EGR is likely closed there won't be a command to close the throttle.
IATS2 is at 28C so it looks like the engine has been operating for about 10 mins.
Could do live data again with ECT, (TVP) BPA, IAT, MAP, MAF, RPM, CAT, APP D E 1 2, D DPF, EGR. Better to have the engine at operating temp. On mine the gauge needle is vertical supposed to = 90C - Forscan ECT is about 70C. The temp shall vary.
2012 MK 7 E 5 100-350 3.5 XLWB RWD Duratorq 2.2L CR TC 14 DSL 100/125 PS E5 DPF BCM PCM RCM
Was DRRB 74 KW 100 HP 100 cv. Now CYR5 125 HP. PCM could still be for 100 HP.
There's more letters after a Transit than a military man
