The problem your having sounds like fuel starvation to me,you will have to clean the gas divider or disributor it's the thing next to the vaparisor with the four
tubes coming out of the top of it and one big tube in the bottom of it.these little tiny slits in side that can get blocked with waxy residue and you can clean them out
with a thin feeler gauge
Cleaning Gas divider.
To clean the gas divider you best remove this out of the van by taking of the 4 small hoses
from the gas divider first.
Then take of the big hose and the 2 electrical connectors.
Check if there is any dirt in the filter from the big hose.
This dirt comes from a bad membrane.(vaparisor)
Then take off the stepper motor by unscrewing out the 2 imbus bolts.
Look out that the piston spring and ring don't jump out because if the
piston is damaged on the stepper motor. it won’t work ever again,
You can pull out the liner with the slits in, mind you don't lose the ballbearing at the top,
The two holes near the top of the liner will help, a hook can be used in the holes to ease it out
Now the cleaning can begin.
Spray brake cleaner into the 6 slits in the divider.
Wait 1 minute before blow the dirt and cleaner out of the divider by air pressure on the 4
output holes.
This can be done 2 or 3 times, so you are sure that al is perfectly clean.
The piston has to be sprayed with a little Teflon spray.
The O-ring needs a little grease before replacing, so it will not damaged by pressing
into the housing.
Refit every thing as reverse.then fit back on van
when all is connected the motor can be started, end everything can be checked for leaking by a
little soap with a little water.
To get more info lookup
http://www.askanowner.com search for necam/koltec in search bar.
it's a great site for our gas problems kver on there knows a hell of alot and works on these gas system's
and can get the parts, hope this can help?
