DETAILS OF YOUR VAN? off Ford ETIS - ask here!!
Re: DETAILS OF YOUR VAN? off Ford ETIS - ask here!!
Postby Westycr » Sat May 11, 2013 10:21 am
Thank you very much jolly olly
Westycr
Postby Kelvfoozinda » Sat May 11, 2013 7:01 pm
Just got a shiney new van from work..could you investigate it for me. They haven't said what power version it is but seems pretty good.
LF13WXC
Cheers.
Kelvfoozinda
Postby jolly olly » Sat May 11, 2013 10:31 pm
Kelvfoozinda wrote:Just got a shiney new van from work..could you investigate it for me. They haven't said what power version it is but seems pretty good.
LF13WXC
Cheers.
* Illustration shows model only
Transit 2006-, 2.2L CR TC I4 DSL 125 PS, Blazer Blue
VIN Number: WF0XXXBDFXDJ55967
Registration Number: LF13WXC
First Registration Date: 26.04.2013
Registration Country: GB
Type Approval Number (TAN): E1*2007/46*0248
Primary Features
Build Date: 14.01.2013
Vehicle Line: Transit 2006-
Cab Style: Regular Cargo Van
Series: 300S Series
Engine: 2.2L CR TC I4 DSL 125 PS
Transmission: 6-Speed Manual Transaxle - VMT6
Drive: RHD FWD
Axle Ratio: 4.36/3.05
Emission: Stage V LDT3 Emissions
Air Conditioning:
Territory: (+)"GB"
Paint: Blazer Blue
Interior Colour: Lichen
Interior Fabric: York Weave
Minor Features
With Medium Roof
Less Roof Line Conversion
With Rear Mudflaps
Less Front Susp'n Skid Plates
Less Interior Pack
Less Front Mudflaps
Narrow Door Width
Low Door Height
With Kerbside Side Load Doors
With Diesel Particulate Filter
Less Back Panel Bulkhead Grille
Less Brake System-Regenerative
With Full Partition - Steel
With Hinged Rear Loading Doors
With 256° Cargo Door Check Arms
With Unrestricted Side Load Dr Opng
Less Folding Step - Side Door Load
Less Rear Door Catch
Less Liftgate
Less Second Unit Body
Less Mesh Headboard 2nd Unit
Less Tailboard Support Straps
Less Auxiliary I/P Console
With Standard GVM Rating
Southampton Plant Built
Less Special Equipment Package
Less Marketing Flex Prep Pack
Less Sales Badge
Less Trim Pack
Less Special Value Packages
Less Power Equipment Group
Marketing Level 3
With Visibility Pack High
Less Dress Up RSO
Less Paint Package
Less Utility Package
Less Certification Label
Less Fire Extinguisher Fixings
With Tool Kit
Less Tyre Repair Service Kit
With Power Front Windows
With All Light Tinted Glass
Less Front Side Door Security Glass
Less 2nd Row RH Side Window
Less 2nd Row LH Side Window
Less 3rd Row RH Side Window
Less 3rd Row LH Side Window
With Rear Blanking Panel
Less Rear Side/Back Security Glass
With Heated Windscreen
Less Heated Rear Window
Less Overhead Console
With Header Mounted Package Tray
Less Rear Compartment Trim Panel
Less Inter Cladding Surfaces
Less Front Floor Mats
Flr Cvr-Rubber Ins-Extended
With Bright Air Vent Knob
With Partial Headlining - Moulded
With Door Map Pocket
Less Interior Grab Handle Side Door
Less Front Roof Grab Handle
Less A Pillar Assist Handle
Less 'B' Pillar Assist Handle
With Load Space Tie Down Loop
Less Load Floor Covering
Less Load Area Protection Kit
Less Cargo Stowage Rack/Rail
Less Load Compartment Tie Down
Drivers Door Trim - Level 2
Passenger Door Trim - Level 1
Less Running Boards
Less Roof Rack
With Narrow Body Moulding
Less Rear Window Protector
Less Rear Step
Less Rear View Mirror
Large Head/Short Arm Mirror
Dual Power Heated Exterior Mirrors
Less Seat Construction
Less Rear Underseat Stowage Bin
Less Drivers Seat Armrest
Less Passenger Seat Armrests
Less Rear Seat Recliner
Less Passenger Seat Valance
Less Seat/Airbag Pack
Less 6th Row Seating
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
Less 2nd Row Rear Seat
Less 3rd Row Rear Seat
Less 4th Row Rear Seat
Less Fifth Row Seating
Less Rear Seats Fixings
Less 2nd Row Reversed Triple Seat
With Driver 6 Way Mnl.Seat Adjuster
Less Adjustable Passenger Seat
Less Removable 2nd Row Seat
Less Rear Seat Armrest Packs
Less Rear Seat Packs
Less Trailer Towing Attachments
Less Trailer Coupling
Less Front Towing Hook
Rear Axle Alternative A
Less Fleet Key
With Door Auto Relocking - Enabled
Less Zonal Opposite Door Relocking
Less Configurable Unlocking
With Door Dead Locks
With Power Lock Group
Two Step Door Unlock System
Less Side/Rr Door Security Lockset
Remote Control Door Entry - 2 Fob
Less Rear Window Wiper/Washer
Rain Sensor - Fr Windscreen Wiper
Less Sun Roof
Less Rear Sunroof
Self Colour Rear Bumper End Caps
Mid Grey Front Bumper
Rear Plastic Grey Bumper-With Step
Less Rear Bumper Under Run
Less Bumper Underrun - Front
Less Rear Seat Belts
With Driver Air Bag
With Passenger Air Bag
Tyre Carrier Drop-Dr Open
Less Side Underrun Rails
Less Float Mounting
With Steel Spare Wheel
With Silver Wheel Finish
With Spare Tyre Security Package
With Single Rear Wheels
5 1/2J x 15 Steel Wheel
195/70R 15C LI 104/102 BSW
With Wheel Hub Cap
Non Locking Lug Nuts
70MPH Engine Governor
Diesel Fuel Cooler
Less Engine RPM Control
Cold Start Up To -20%c
Standard Electric Starter Motor
Dual Mass Flywheel
With Standard Attitude/Ride Height
With Standard Duty Front Suspension
Front Axle Rating-Normal
With Front Stabilizer Bar
With Standard Duty Rr Leaf Springs
Less Rear Auxiliary Springs
With Standard Rear Suspension
Less Rear Stabilizer Bar
With Down Turned Exhaust Exit
With Tunnel Mounted Parking Brake
Power 4-Wheel Disc Vacuum Boost
4 Wheel Anti-Lock Braking System
Electronic Stability Brk Ctrl (ESP)
Less Transfer Case
Less Skid Plates
With Sngle.L/B Dvr/Dual L/B Pass.St
Less Rear Seat Climate Control
Less Heater
With 80 Litre Fuel Tank
Less Fuel Water Separator
With Diesel Fuel Capability
With Power Steering(Variable Ratio)
Basic Type Steering Wheel
Less Auxiliary Heater
Less Heater/Air Con Prep Pack
Less Auxiliary Hot Water Heater
Less Rear Compartment Heating
With MPH/KMH Speedometer
Less Tachograph
Less Tripminder Assy
With Tachometer
Less Navigation Disk
Less Navigation Data
Less Seat Belt Warning Light
With Reverse Proximity Sensor
Thatcham Catergory 1 Alarm System
Less Engine Immobiliser
Extra Heavy Duty Battery
Drivers Seat Rechargeable Battery
Standard Duty Alternator
Less Radio Pre-Equipment Pack
Less Bluetooth
Roof Mounted Radio Antenna
ICE-Low Level CD + AM/FM Radio
Ice Feature Pack 5
With 2 Speakers
Less Telephone
Less Telephone Preparation Pack
Less Microphone
Less Voice Activated Modules
With Column Stalk Radio Controls
Electrical Outlet
Less Smokers Package
Less Power Point Plug - Rear
Less Camera
Less Optional Equipment Pack
Less Wheel Pack
Less Aero Pack
With Daytime Running Lamps
With Front Fog Lamps
Less Roof Marker/Clearance Light
Less Footwell Lights
Less Interior Courtesy Lamp
Less Load Compartment Lamp
Less Side Marker Lamps
With High Mounted Stop Lamp
Life is not a dress rehearsal
jolly olly
Postby Airthies » Mon May 13, 2013 11:47 am
Hi looking for more info on a welfare van please,
Reg No.ND56 PJY
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby jolly olly » Mon May 13, 2013 9:17 pm
Airthies wrote:Hi looking for more info on a welfare van please,
Reg No.ND56 PJY
Transit 2006-, 2.4L Duratorq-TDCi (115PS) - Puma, Frozen White
VIN Number: WF0XXXTTFX6J77965
Registration Number: ND56PJY
First Registration Date: 26.10.2006
Primary Features
Build Date: 21.05.2006
Series: 350L Series
Engine: 2.4L Duratorq-TDCi (115PS) - Puma
Transmission: 6 Speed Manual Transmission-MT82
Drive: RHD RWD
Axle Ratio: 3.73
Emission: Stage IV Emissions
Territory: (+)"GB"
Paint: Frozen White
Interior Fabric: Tomy (G-C)
Minor Features
With High Roof
High Door Height
Otosan (Turkey) Plant Build
Less SVO Application/Label
Less Trim Pack
Marketing Level 3
European Environmental Label
With Manual Front Windows
With Clear/Light Tinted Glass
With Front Roof Grab Handle
With Cargo Stowage Rail (Mid)
With Drivers Seat Fixed Armrest
With Front Towing Hook
With Door Entry Remote Control Unit
Less Passenger Air Bag
Less Float Mounting
Less Diesel Fuel Cooler
With Brake Only Traction Control
Less Transfer Case
Less A/C Unit - Roof Mounted
With Recirculating Heater
Fuel Water Separator Less Sensor
Less Reverse Proximity Sensor
With Radio Pre-Equipment Pack 1
Ice Feature Pack 2
Less Column Stalk Radio Controls
With Manual Headlamp Levelling
Less Battery Cut Off Relay
Less Roof Flasher Wiring
Less Auxiliary Fuse Panel
jolly olly
Postby Airthies » Mon May 13, 2013 9:34 pm
cheers jolly olly, much appreciated.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Memster » Tue May 14, 2013 1:36 pm
Been looking at buying a newer van, the details arnt coming up on ford etis? It was on a private plate, but thats not showing anything either.... should I be concerned?
Memster
Postby OllyG » Tue May 14, 2013 7:04 pm
Hi there, could I get the info for this van please, reg = BJ06 RXZ. Thanks a lot
OllyG
Postby jolly olly » Tue May 14, 2013 10:32 pm
Memster wrote:Been looking at buying a newer van, the details arnt coming up on ford etis? It was on a private plate, but thats not showing anything either.... should I be concerned?
No just get the VIN number for the check.
jolly olly
Postby jolly olly » Tue May 14, 2013 10:33 pm
OllyG wrote:Hi there, could I get the info for this van please, reg = BJ06 RXZ. Thanks a lot
Transit 2000-2006, 2.4L Duratorq-TDCi (115PS) - Puma, Diamond White 73
VIN Number: WF0LXXTTFL6S28112
Registration Number: BJ06RXZ
First Registration Date: 22.05.2006
Primary Features
Build Date: 08.03.2006
Vehicle Line: Transit 2000-2006
Series: 350L Series
Transmission: 5-Speed Manual Transmission - MT75
Drive: RHD RWD
Axle Ratio: 5.13
Emission: Light Duty Truck Stage III
Territory: (+)"GB"
Paint: Diamond White 73
Interior Colour: Dark Graphite
Interior Fabric: Stylize (-G-C)
Minor Features
With High Roof
LH Sliding Side Cargo Door - High
Marketing Level 3
With Complete Rear Hardboard Trim
With Rear Step - Centre
Passenger Lrg Head/Short Arm Mirror
Fleet Key
With Grey Plastic Rear Bumper
With Driver Air Bag
215/75R 16C BSW Tyres
Any Brand Tyre Vendor
With Improved Attitude/Ride Height
With Manual Clutch
4000 Series
With Power Point Plug
With Load Compartment Lamp
Less High Mounted Stop Lamp
jolly olly
Postby wm9709clarke » Tue May 14, 2013 11:36 pm
hi everyone can someone please give me more information on my bus please its a mk6 2002 15 seat transit minibus reg num ng02 hau i bought this last year with intension of doing her up but things took over and now im getting her sorted.
i had a problem with the central locking the door locks would just bounce back open so ive changed the central locking module and now the doors lock but the front doors bounce straight open again and when i try to manually lock it from the drivers side only the drivers side locks am i correct in thinking it must be either the wires to the drivers door or the lock itself thanks in advance for any info that will help me resolve this problem
wm9709clarke
Postby TIMO » Wed May 15, 2013 12:41 am
I have had a lot of trouble with mine too.. mainly the cable (not wire) from the deadlock switcth in the drivers door... also.. connections in the Aframe seem to keep coming loose .
Transit 2000-2006, Duratorq DI 2.4 (90PS), Diamond White 73
VIN Number: WF0EXXGBFE2J01475
Registration Number: NG02HAU
First Registration Date: 06.06.2002
Primary Features
Build Date: 15.05.2002
Cab Style: Bus (M2)
Series: 350L Series
Engine: Duratorq DI 2.4 (90PS)
Drive: RHD RWD
Axle Ratio: 5.13
Territory: (+)"GB"
rivers door .
BBC = British Broadcasting Conspiracy
http://www.youtube.com/watch?v=nj82wxnO ... r_embedded
TIMO
Postby Gaz-M » Wed May 15, 2013 1:38 pm
My Recovery pretty please.. WU07 ZTX
Thanks in advance! :wink:
Gaz-M
Postby karl » Wed May 15, 2013 2:35 pm
Gaz-M wrote:My Recovery pretty please.. WU07 ZTX
Primary Features
Build Date: 15.08.2006
Cab Style: Single Cab (2 Door)
Series: 350M Series
Drive: RHD RWD
Axle Ratio: 3.73
Territory: (+)"GB"
Paint: Frozen White
Minor Features
Less Side Load Doors
Less Bulkhead
With Aux I/P Console - 2 Din Horznt
Incomplete - Ship To VFS
Less Trim Pack
Marketing Level 3
With Fixed Rear Window
With Black Air Vent Knob
Large Head/Long Arm Mirror
Less Float Mounting
With Double Rear Wheels
5 X 16" Steel Wheel
Less Wheel Covers
Less Transfer Case
Less Deep-Discharge Batteries
Ice Feature Pack 2
Less Wheel Pack
With Roof Flasher Wiring
With Auxiliary 6 Fuse Box
karl
Tranny Lover!!!
Postby Gaz-M » Wed May 15, 2013 3:44 pm
Thanks a lot!
Gaz-M
