DETAILS OF YOUR VAN? off Ford ETIS - ask here!!
Re: DETAILS OF YOUR VAN? off Ford ETIS - ask here!!
Postby hodgy111 » Sat May 18, 2013 12:56 am
* Illustration shows model only
Transit 2000-2006, Duratorq DI 2.0 (100PS), Diamond White 73
VIN Number: WF0TXXGBFT2A22427 Registration Number: SO52GKC First Registration Date: 10.01.2003 Registration Country: GB Primary Features Build Date: 28.11.2002 Vehicle Line: Transit 2000-2006 Cab Style: Bus (M1 LRF) Series: 300S Series Engine: Duratorq DI 2.0 (100PS) Transmission: 5-Speed Manual Transaxle - VXT75 Drive: RHD FWD Axle Ratio: 4.23 Emission: Light Duty Truck Stage III Air Conditioning: Manual Air Conditioning Territory: (+)"GB" Paint: Diamond White 73 Interior Colour: Dark Graphite Interior Fabric: Vertigo G-C
Would someone be able to tell me if my minibus is dual mass flywheel or solid please
hodgy111
Postby ake » Sat May 18, 2013 7:32 am
hodgy111 wrote:* Illustration shows model only
At that age it could be single mass, the earlier 100ps had dual.
Postby Plim » Mon May 20, 2013 1:42 am
Hi would someone be kind enough to access ETIS as i am to upgrade ?? my 1999 smiley n/a for a 2.o litre transit reg number MF52 UMA thanks in advance Mark
Plim
Postby itz.the.fatboy » Mon May 20, 2013 8:18 pm
Hi can somw one tell me what axle my truck as its pj02svu and also weather its towing or whatever the others are thanks jim
itz.the.fatboy
Postby jolly olly » Mon May 20, 2013 10:45 pm
Plim wrote:Hi would someone be kind enough to access ETIS as i am to upgrade ?? my 1999 smiley n/a for a 2.o litre transit reg number MF52 UMA thanks in advance Mark
Unable to Locate Information for the Vehicle Data
We are sorry, but no information could be found for the VIN/Registration number you entered - MF52UMA
Click here to check and re-enter the information you supplied.
©Copyright, Ford Motor Company 1994 - 2013 | Privacy Policy
Action took 37 ms. on eccvas509
Life is not a dress rehearsal
jolly olly
itz.the.fatboy wrote:Hi can somw one tell me what axle my truck as its pj02svu and also weather its towing or whatever the others are thanks jim
We are sorry, but no information could be found for the VIN/Registration number you entered - PJ02SVU
Action took 40 ms. on eccvas509
jolly olly
Postby itz.the.fatboy » Tue May 21, 2013 12:42 am
Thanks so would I need vin ?
itz.the.fatboy
Postby ake » Tue May 21, 2013 6:32 am
Yes
Postby scrapman1 » Tue May 21, 2013 10:22 am
Sd52vyy
scrapman1
Postby Plim » Fri May 24, 2013 1:30 am
Mystery solved MF52 UMA was original registered to the NHS so not liable for RFL bought the van VIN checked on ETIS and all was reviled thanks for having a look though Regards Mark
Plim
Postby jolly olly » Fri May 24, 2013 11:20 pm
scrapman1 wrote:Sd52vyy
Transit 2000-2006, 2.0L Duratorq DI (75PS), Diamond White 73
VIN Number: WF0VXXBDFV2B53904
Registration Number: SD52VYY
First Registration Date: 30.10.2002
Primary Features
Build Date: 18.09.2002
Cab Style: Regular Cargo Van LCF
Series: 280S Series
Engine: 2.0L Duratorq DI (75PS)
Drive: RHD FWD
Axle Ratio: 4.54
Territory: (+)"GB"
Interior Fabric: Stylize (-I-C)
jolly olly
Postby fixer165 » Sat May 25, 2013 3:17 pm
hi there can one of you fellas do a etis for my van sh05 mdx thanks
VANTUNER.COM WELL SORTED
fixer165
Postby blue estate » Sat May 25, 2013 3:20 pm
fixer165 wrote:hi there can one of you fellas do a etis for my van sh05 mdx thanks
Primary Features
Build Date: 17.03.2005
Cab Style: Single Cab (2 Door)
Series: 350M Series
Engine: Duratorq DI 2.4 (90PS)
Transmission: 5-Speed Manual Transmission - MT75
Drive: RHD RWD
Axle Ratio: 5.13
Territory: (+)"GB"
Interior Fabric: Stylize (-G-C)
Minor Features
• With Low Roof
• Southampton Plant Built
• Less SVO Application/Label
• Marketing Level 3
• Less Header Mounted Package Tray
• With Partial Headlining - Moulded
• With Roof Height Feature Pack 3
• With Door Map Pocket
• With Front Roof Grab Handle
• Drivers Door Trim - Level 2
• Passenger Door Trim - Level 1
• Large Head/Long Arm Mirror
• Passenger Lrg Head/Long Arm Mirror
• With Drivers Seat Fixed Armrest
• Less Passenger Seat Armrests
• Less Passenger Seat Valance
• Less Temp Control Driver Seat
• Less Temp Control Passengers Seat
• With Driver 6 Way Mnl.Seat Adjuster
• Less Adjustable Passenger Seat
• Fleet Key
• With Door Dead Locks
• With Door Entry Remote Control Unit
• With Driver Air Bag
• With Double Rear Wheels
• 5 X 16" Steel Wheel
• Any Brand Tyre Vendor
• 70MPH Engine Governor
• Less Engine RPM Control
• Cold Start Up To -20%c
• Type 53 Rear Axle 5720lb(2600 Kg)
• 4 Wheel Anti-Lock Braking System
• With Sngle.L/B Dvr/Dual L/B Pass.St
• With Manual Clutch
• With Recirculating Heater
• With MPH/KMH Speedometer
• With Radio Pre-Equipment Pack 1
• 4000 Series
• With Manual Headlamp Levelling
blue estate
Postby fixer165 » Sat May 25, 2013 3:37 pm
thanks blue estate
fixer165
Postby ovlov » Sat May 25, 2013 9:57 pm
Can some one do etis for my van plz :) BN59 YGA
I want to live forever so far so good
ovlov
