mk7 discs and pad change
Postby roscomcc » Tue Jan 17, 2012 10:46 pm
changing discs and pads on my mk7 2007 t350 lwb this weekend any info i should know that would be useful thanks ie is there any torque settings handy tips i should know thanks???????
roscomcc
Re: mk7 discs and pad change
Postby El transito » Wed Jan 18, 2012 7:56 pm
Fronts are straight forward enough, though the bearings can be a "challenge" to get out of the strut 5 X T50 bolts hold the bearing in.
Rears also straight forward, N/S caliper winds back anti-clock which is a pain if you have a clockwise only wind-back tool.
El transito
Postby blue estate » Wed Jan 18, 2012 8:00 pm
make shure you take the stub axle out on the front before removing hub 36mm nut
mk2.5 Focus zetec 1.8tdci 09 hatch
mk4 Escort estate 1.3no 1.4 yellow
My other car is a 44t MAN TGX 480 tractor unit
blue estate
Postby El transito » Wed Jan 18, 2012 9:01 pm
blue estate wrote:make shure you take the stub axle out on the front before removing hub 36mm nut
Very good advice, undo the 36mm nut with the wheel on floor before you start.
El transito
Postby roscomcc » Wed Jan 18, 2012 11:04 pm
thanks for the tips but is there any torque setings for bearing nuts or just tighten till no end float???
roscomcc
Postby El transito » Wed Jan 18, 2012 11:20 pm
roscomcc wrote:thanks for the tips but is there any torque setings for bearing nuts or just tighten till no end float???
The bearings are parallel running not tapered roller, think torque setting is 425lb/ft, or very tight if you don't have a torque wrench that goes that high.
El transito
Users browsing this forum: Bing [Bot], Google [Bot]
