Speed limiter removal
Postby hdndriver » Wed Feb 22, 2012 9:19 pm
My mk7 2.2 110 has a factory fitted limiter which i want removed, several tuning companies have quoted me £150+vat. I spoke to my local ford dealers and they will do it for £70+vat providing i give them written permission. My problem is that i then told them i'd had my van remapped and they have said that when they plug in there computer it may fry my ecu, i dont mind if they wipe the map as tuning company will put it back on for free but i just wanted to know if they are scare mongering or is there a real chance of screwing it up, also will they do a pcm update at the same time ? Any advice would be extremely helpful.
hdndriver
Re: Speed limiter removal
Postby Mike » Wed Feb 22, 2012 9:23 pm
You need to speak to Martynx for the definitive answer but I think it's extremley unlikely that your ecu would be fried, but it'll almost certainly wipe the map.
Martynx can do the limiter without removing the map afaik.
Mike
Wind up merchant!
Postby Backbone of Britain » Wed Feb 22, 2012 11:12 pm
I had the 70 mph speed limiter removed from my MK6 at the dealer cost me £75+vat. Like you said I had to give written permission for them to remove it and produce the V5 to prove I owned the van. It never fried my ecu so can't see that happening. Can't see any problens as all they do is plug it in to IDS and turn the speed limiter off. 5 minute Job but they'll probably keep you waiting 1/2 an hour :lol: It will only wipe the map if they update the pcm.
2006 Mk6 115 T350 LWB Highroof
2008 Mk7 115 T350 LX LWB Highroof
Backbone of Britain
Postby Guy88 » Thu Feb 23, 2012 12:28 am
they dont touch the map when removing the limiter,
the limiter is done thru the car config, only limiter in the map is the 100 mph
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby transitvan1234 » Thu Feb 23, 2012 4:55 pm
i had the ford agent do mine mine was remaped as well dont tell them it was remaped they did my egr at the same time the done mine for £50
transitvan1234
Postby maycontainnuts » Fri Feb 24, 2012 11:20 pm
where are you based I can turn it off for you for £35
1983 mk2 2.4 swb
2006 mk6 transit recovery truck
2008 mk7 service van
maycontainnuts
Postby Nick Storm » Sun May 20, 2012 3:09 pm
I have a 2001 350 which has a limiter. (mk6?)
Anyone knwo how they work? Do they stop injecting fuel or something else?
Cheers,
Nick
Nick Storm
Postby ake » Sun May 20, 2012 5:50 pm
Yes they reduce the fuelling to control the seed, all done through the ecu
Postby Coreylee123 » Sat Oct 18, 2014 1:34 pm
Hi does anyone no anywhere and how much it would cost to get restricter removed from my 2.2 swb transit as this was an ex AA and won't go above 70 on a motorway also sluggish round town and with it been 110 boho thought it would be quicker than it is thanks
Coreylee123
Postby Liliflower » Wed Dec 24, 2014 4:53 am
Another thread discuss over the issue
viewtopic.php?f=65&t=150273&p=1297009#p1297009
Liliflower
