Hi all, new to this forum and need some adviceI
I have a 52 reg 2002 Diesel,260 SWB, FWD. The front brake calipers were sticking and eventually stuck solid.I fitted 2 new reconditioned calipers, bled the brakes and thought that was it. However several weeks later the brakes are starting to stick after the pedal is released and the pedal also feels hard to push whilst driving.
I disconnected the pipe (with the one way valve in it) from the servo and also disconnected it from the quick release connector at the vacuum pump end.
Blew throught it in the direction of the vacuum pump and there was no resistance whatsoever, however blowing from the other direction i could just manage to blow through it, and i mean just a tiny bit. Would this cause the problem of sticking calipers ?
Any help appreciated.
judd
