nedforceone wrote:bambi mk 1 wrote:the dutch guy wrote:[quote="withers1"]Did u need to have the ecu programed for the egr deleation plate or not m8
not with a 125 TDCI.
You need to delete the whole van if its a mk 6 tdci withers van is a mk 7 so it needs the ecu programmed
birdie wrote:
2 new batteries in my bus today
How the fook was that drivable..... Better give the turbo a check as wellChillitt wrote:Booked the van in for it's MOT, on the way back engine light came on, looking at the date on the fuel filter, I think I know what the problem is.. Also think the airfilter might be passed its best.
andz327 wrote:How the fook was that drivable..... Better give the turbo a check as wellChillitt wrote:Booked the van in for it's MOT, on the way back engine light came on, looking at the date on the fuel filter, I think I know what the problem is.. Also think the airfilter might be passed its best.
If yr needing the holes opened I've a step drill in the van.andz327 wrote:Yeah new peepers but couldn't find ma cone cutter to enlarge side light holes for led sides and fitted new crank pulley to go with new tensioner, belt and idlers x2 from other day .....been an expensive weeknedforceone wrote:New headlights Andz, is it time for another oil cooler to sh*t the bed You'll be blinding everyone now with your bright lights N
Nice one......Airthies wrote:If yr needing the holes opened I've a step drill in the van.andz327 wrote:Yeah new peepers but couldn't find ma cone cutter to enlarge side light holes for led sides and fitted new crank pulley to go with new tensioner, belt and idlers x2 from other day .....been an expensive weeknedforceone wrote:New headlights Andz, is it time for another oil cooler to sh*t the bed You'll be blinding everyone now with your bright lights N
Geez a shout and will sort you out and cheer up yr week for you.
(Check yr PM's)
andz327 wrote:Seen a beast today and fell in love,silver twin wheel jumbo 5 pot 200bhp beastie mk7.....I'm thinking lottery win required to get one of these
tony&kasia wrote:My van runs sweet as a nut again
They put in another set of injectors Well he said he made up another set
Now i have to replace the inside door handle on the sliding door
Apparently she could not open it because it snapped
Good job i kept the old door with all the bits on
Can i fix it from the inside or do i slide off the door We will see
nedforceone wrote:tony&kasia wrote:
I will just see how the spare of the moment goes if i get white smoke. At the mo bloody fuming as this is 3rd time back to a billy the kid
Can you not just pop back to paul2012? Probably be sorted in 10 mins. N
