Punto443 wrote:Another puncture!
Stop buying magnetic tyres N
MrFlibble wrote:
The large chisel I was using to lever the gearbox off the engine slipped and squashed my thumb against the chassis crossmember that runs under the engine
I blame Tango and Brains for goading me into doing the job
That'll buff right out...
I feel your pain mate....did the same thing myself when I slipped with a tyre iron changing a tyre on my motorcycle...squealed like a little girl I did..!
Airthies wrote:Well been offered the van at a reasonable price so going to be the official owner of two 2008 mk7 115/350 vans soon! So had it hooked up and recheckrd for any codes, all good, then whipped off the speed limiter and changed the radio to 4 speakers so can get some in the back for working.
Going to need a bit of talc as it's had a few drivers an done 159k. It's got a bit of a whiney diff and one or two minor bits to get sorted but it's had bonnet and windscreen roof panel painted last year so looks good from the front.
Happy days.
heehaw tae see here, please shift along.
MrFlibble wrote:Well, I'd better post some photos, since if I don't, Punto will be claiming that it never happened...
One mangled clutch:
Curiosity got the better of me and I cut the driven plate apart to see what broke.
Notice the ring above and just to the right of the driven plate - a couple of splits in it. Plus a few of the small springs are completely knackered.
And, to change the topic to "What did your Mk6/7 do to you today?":
Beaker wrote:Fitted a Hykee lock to my drivers door. Took me twenty minutes just to get the retainer pin pushed in on the original lock - just could not get it to move. Once it did, it was easy peasy. I feel a lot happier now as there has been loads of vans nicked or broken into locally in the last few weeks.
Brains_transit wrote:Well now you've done it you can now say it's easy enough
MrFlibble wrote:Brains_transit wrote:Well now you've done it you can now say it's easy enough
Not yet. I've got the old one off now, but not fitted the new one yet. Still got the difficult bit of centering it up without disturbing the self-adjusting mechanism to come.
Users browsing this forum: Chug, Google [Bot]
