Brains_transit wrote:Once it's 1500 pages wipe it and start from new that should wipe out the mk6 section
Punto443 wrote:Got carried away at the signwriters
Brains_transit wrote:I would just remove the light and strip the electrical bit and fill it with water and cleaning fluid and shake the light to clean inside
andz327 wrote:Brains_transit wrote:I would just remove the light and strip the electrical bit and fill it with water and cleaning fluid and shake the light to clean inside
Surely you Don't you think I never washed the lamp out when I had front end off to clean the exxon valdez disaster........ its the detergent /cleaning fluid and water that fooked it mate, thats not oil you see in the picture is black plastic showing through the silver surround in the lamp
Sent from my D6603 using Tapatalk
nedforceone wrote:Brains_transit wrote:Once it's 1500 pages wipe it and start from new that should wipe out the mk6 section
I'll still be lurking in the shadows N
andz327 wrote:nedforceone wrote:Brains_transit wrote:Once it's 1500 pages wipe it and start from new that should wipe out the mk6 section
N how can you lurk in any shadows with all them fookin lights on
andz327 wrote:andz327 wrote:Brains_transit wrote:I would just remove the light and strip the electrical bit and fill it with water and cleaning fluid and shake the light to clean inside
But I appreciate the brains behind your answer
andz327 wrote:Already had GreenPeace knocking on ma door this morning......
andz327 wrote:But I appreciate the brains behind your answer
Users browsing this forum: Google Adsense [Bot], MSN [Bot]
