bigjohnthomas wrote:its the bloody arse wash messing about again
think i need a mk8 oink oink
ned wrote:Put a new battery in the inside/outside temperature thing as the ice warning kept going off, bloody lidl. N
loot wrote:ned wrote:Put a new battery in the inside/outside temperature thing as the ice warning kept going off, bloody lidl. N
Maybe it is confused by the bass box?
Tango330 wrote:Tried to work out why it sounds like something is loose on the front end when I drive up our lane, all looks alright under there though
ned wrote:Tango330 wrote:Tried to work out why it sounds like something is loose on the front end when I drive up our lane, all looks alright under there though
Could be a lower ball joint, track rod end or tie bar thats buggered. N
Tango330 wrote:ned wrote:Tango330 wrote:Tried to work out why it sounds like something is loose on the front end when I drive up our lane, all looks alright under there though
I'll have to get under it again and give it a proper coat of looking at Mate. Didn't seem to be anything loose there when I jacked it up, but I was in a rush
loot wrote:I replaced the strut top bearing and cup thing on my van, not required though tbh, I think the steering would be rough or notchy if it was that bad, also when the load is on it probably wouldn't clonk, you'd need to jump I think
But jack front up and feel for roughness when manually steering the the road wheel.
Although I still doubt you'd feel much unless it was fubar.
Arb are common and drop links and wb bushes.
You might need to hit a few policeman at 65 to find the culpret though
ned wrote:loot wrote:I replaced the strut top bearing and cup thing on my van, not required though tbh, I think the steering would be rough or notchy if it was that bad, also when the load is on it probably wouldn't clonk, you'd need to jump I think
Like your thinking N
