What did you do to your mk6/7 today?
Re: What did you do to your mk6/7 today?
Postby squirrel93 » Wed Mar 21, 2018 8:58 pm
Punto443 wrote:Just get a mk6 tddi and it’ll never break down.
Oh, wait a minute? You have one :lol:
it’s getting on in life , it’s doing around 2.5-3k miles a month
squirrel93
Postby Airthies » Wed Mar 21, 2018 10:35 pm
Tried to do module programming with forskin but failed. Was looking promising for a high spec BCM swap, all good till going to save config and load then several failure logs and it stuck at 34%
Left it for about 10-15mins with no change in case it was just working in background then gave up and stuck original back in.
At least it does in and out codes all by itself .
Need to have a better play and a bit more reading up on the forscan forum.
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Wed Mar 21, 2018 11:00 pm
Airthies wrote:Tried to do module programming with forskin but failed. Was looking promising for a high spec BCM swap, all good till going to save config and load then several failure logs and it stuck at 34%
We could do with an exhaustive list of what does what :mrgreen:
Ids map here
loot
Postby Airthies » Wed Mar 21, 2018 11:22 pm
It's a work in progress....
When installing the BCM it wanted the calibration file rather than the asbuilt and it seemed to pickup the original config of the new (s/h) BCM so thinking it's something to do with what sequences things are done but trying to workout the terminology difference between it and IDS for certain processes I'm not sure if I went about it all the right way. But the config menu is good I'll give it that. Once you've got the full version of foreskin that is, not one of the circumcised versions.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Wed Mar 21, 2018 11:26 pm
At some stage with all this coding and stuff I bet some clever sod will put a nice shell on it that is intuitive.
Be nice to have something like that 8)
Ids map here
loot
Postby Airthies » Wed Mar 21, 2018 11:31 pm
loot wrote:
Airthies wrote:
loot wrote:[quote="Airthies"]Tried to do module programming with forskin but failed. Was looking promising for a high spec BCM swap, all good till going to save config and load then several failure logs and it stuck at 34%
Be nice to have something like that 8)[/quote]Yea first time I've had a proper play with it other than reading and clearing codes but it is fairly intuitive but some of the advanced programming options arnt what I'd expected.
Would be nice to have an elm which would switch itself between MS/HS CAN cos it's really hard and inconvenient to keep flicking a wee switch
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Wed Mar 21, 2018 11:44 pm
Be nice to be able to fit something that switches the ignition too :lol:
Ids map here
loot
Postby Airthies » Wed Mar 21, 2018 11:53 pm
loot wrote:Be nice to be able to fit something that switches the ignition too
Or a good manservant. Would BJT hire out his footman?
V86+patch
V86.04
X-Prog
C81
Airthies
Postby dirtydog » Thu Mar 22, 2018 1:36 am
Just ordered an Elm 327 from Amazon
dirtydog
Postby motorman116 » Thu Mar 22, 2018 1:24 pm
Washed, dried, polished and waxes my van :D
2008 3.2 5 pot diesel Ford Transit GLX Lwb, Hr
motorman116
Postby ned » Thu Mar 22, 2018 1:33 pm
dirtydog wrote:Just ordered an Elm 327 from Amazon
Did you get WiFi, Bluetooth or wired for Ford, Lincoln, Mazda. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby loot » Thu Mar 22, 2018 3:41 pm
:shock: I think this forum is rubbing off on you Ned :P not so long ago your question would have been....... Does it have lights on it?
:lol:
Ids map here
loot
Postby ned » Thu Mar 22, 2018 4:00 pm
:lol:
:lol: :lol: mine has lights on it :wink:
5 of them :mrgreen: N
ned
Postby loot » Thu Mar 22, 2018 4:11 pm
I've got 1 of those but there's no switch on it so I bought a usb 1 with a switch :-)
Ids map here
loot
Postby ned » Thu Mar 22, 2018 4:34 pm
loot wrote:I've got 1 of those but there's no switch on it so I bought a usb 1 with a switch :-)
Ah yes the can bus switch, see I do learn stuff :wink: the only can bus for my van is, can = panel van, bus = tourneo :lol: :lol: N
ned
