What did you do to your mk6/7 today?
Re: What did you do to your mk6/7 today?
Postby Airthies » Wed Feb 14, 2018 1:20 am
andz327 wrote:
Airthies wrote:So that's about 4hrs to get a wishbone out and the rear bolt and bush sleeve are actually still there getting too old for this laying on the ground faffing around under vehicles!
It's a grinder job tomorrow! Too late at night for it now! Image at least I got to it eventually.Imagebut the bolts tight in the sleeve
Imageit's bloody tight in the sleeveImageit's too bloody tight it'll get the grinder work tomorrow.
And bad mood stopped play
Not just bloody cold temps....
Welcome to my world mate
But you don't crawl under stuff for a job... give me heavy plant anyday!
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby andz327 » Wed Feb 14, 2018 3:50 am
Maybe not now but i used to ......and l'm talking about an easy job turning into a nightmare and usually snowing or pissing it down...
andz327
Postby Airthies » Wed Feb 14, 2018 8:58 am
andz327 wrote:
Airthies wrote:
andz327 wrote:[quote="Airthies"]So that's about 4hrs to get a wishbone out
Maybe not now but i used to ......and l'm talking about an easy job turning into a nightmare and usually snowing or pissing it down...[/quote]
Yea I'm with you on that
V86+patch
V86.04
X-Prog
C81
Airthies
Postby andz327 » Wed Feb 14, 2018 7:50 pm
Airthies wrote:
andz327 wrote:
Airthies wrote:[quote="andz327"][quote="Airthies"]So that's about 4hrs to get a wishbone out
Sent from my anu5 using crapatalk[/quote]Suprised you've not got gas welding/ burning gear mate
andz327
Postby dirtydog » Thu Feb 15, 2018 12:57 pm
Found a couple more random plugs on the van today
This one is above the passenger side wheel arch
This one is behind the panel on the drivers side below the steering wheel
There were a couple of others but I didn't take pictures
dirtydog
Postby motorman116 » Thu Feb 15, 2018 1:42 pm
Fitted 2 new Led side light bulbs
2008 3.2 5 pot diesel Ford Transit GLX Lwb, Hr
motorman116
Postby Airthies » Thu Feb 15, 2018 2:07 pm
andz327 wrote:
Airthies wrote:
andz327 wrote:[quote="Airthies"][quote="andz327"][quote="Airthies"]So that's about 4hrs to get a wishbone out
Sent from my anu5 using crapatalk[/quote]Suprised you've not got gas welding/ burning gear mate[/quote]I do but not got gas as can't justify it for the amount I need it just now.
But it's passed now!
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Airthies » Thu Feb 15, 2018 2:17 pm
Finished off mot work.
Full repipe of the brakes. Clean up rear disks. Clean front caliper slides,
& One side light bulb.
Finished last night was just after one by the time I'd cleared up.
But I can officially state that
You can do the whole job with 2 x25ft rolls of tube and 14 fittings (I used 16 and a female connector as I wasn't on the ball and had to put a joint into one of the front to rear pipes)
If your sensible you can do one front to rear and rh front pipe from one roll and the second f-r , rh front and rear axle pipes from the second roll.
Just checked gov site and Mrs must of had it for retest as it's got a stamp till 16/2/19
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Airthies » Thu Feb 15, 2018 2:18 pm
Oh and the bloody wishbone
V86+patch
V86.04
X-Prog
C81
Airthies
Postby andz327 » Thu Feb 15, 2018 5:45 pm
It's only a bush wots up wiv lad
Must be brake pipe season , ma n/s main burst on way to invernessy at 5am monday morning just at Dunblane roundabout
andz327
Postby ned » Thu Feb 15, 2018 5:54 pm
dirtydog wrote:Found a couple more random plugs on the van today
You need to give it a bloody good clean under there :wink: N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby dirtydog » Thu Feb 15, 2018 7:50 pm
Shhhhh! Once the glove box is back in you can’t see it, out of sight out of mind :lol:
dirtydog
Postby invernessguy » Sat Feb 17, 2018 12:31 am
Ordered a couple of front tyres from Asda tyres, cheap as. Tyres are just legal, but had fun trekking up the a9 last night in the snow, and not going back down the road without new ones! Beer o’clock till Tuesday!
Any recommendations for headlight bulbs? My dip is darker than a dark thing on a dark night
Now located in Stirling!
invernessguy
Postby Punto443 » Sat Feb 17, 2018 1:18 pm
Rear caliper rebuild day :)
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby blue estate » Sat Feb 17, 2018 2:01 pm
Punto443 wrote:Rear caliper rebuild day :)
All that fine Cheshire salt taking its toll then :wink: :lol: :lol: :lol:
72plt MG 5 ev estate Battery car
blue estate
