dirtydog wrote:Replaced passenger side brake pipe from the abs unit to the wheel, only problem I've got now is my elm327 won't do the abs service bleed
ned wrote:dirtydog wrote:Replaced passenger side brake pipe from the abs unit to the wheel, only problem I've got now is my elm327 won't do the abs service bleed
What you running it through a laptop or phone app? N
Punto443 wrote:dirtydog wrote:Replaced passenger side brake pipe from the abs unit to the wheel, only problem I've got now is my elm327 won't do the abs service bleed
Get s oneway valve on the calipers and start the engine and pump a good 1/2 litre through each pipe
the dutch guy wrote:thats a normal driver side door...
adam75pl wrote:Got a quote from Ford for injector seals, clamps and bolts.
£258
Seems a lot...
Ford for bolts and uprated clamps (if there not done yet as old ones CAN snap).adam75pl wrote:adam75pl wrote:Got a quote from Ford for injector seals, clamps and bolts.
£258
Seems a lot...
Who knows where I can get those items cheaper?
Airthies wrote:Ford for bolts and uprated clamps (if there not done yet as old ones CAN snap).
A reasonable cost.
eBay/diesel specialist for copper washer and rocker cover & leak off pipe seals.
