loot wrote:I normally have cheap budgets
Tango330 wrote:bigjohnthomas wrote:Arsewashing and dumping the water in the street is making g some good black ice patches in the road today
Can't hang around for granny to slip on it and break her hip though
The next arse beckons
The dragon just told me that the next arsewash for the Cocker is going to be 42 turnips you're wshing in the wrong county BJ
Digrizrat wrote:mike10 wrote:Digrizrat wrote: Happy I'd thought to put the key under the van, not in the glove box!
Mine is on my key ring..... I never even thought about putting it elsewhere.
For a key I've needed once in a year and a half? I didn't want to carry it around. Seems only idiots like me need to be reminded they may someday need it.
ned wrote:bigjohnthomas wrote:Arsewashing and dumping the water in the street is making g some good black ice patches in the road today
Are you allowed to call it that Is it not invisible ice Bloody brexit. N
bigjohnthomas wrote:ned wrote:bigjohnthomas wrote:Arsewashing and dumping the water in the street is making g some good black ice patches in the road today
Yes its because of brexit Ned
ts truly horrid just look at what's going to happen to the tripe industry after it
Altransit wrote:loot wrote:I normally have cheap budgets
No wonder you think FWD are all cr*p
If you want to make best use of the superior handling of a FWD Transit, then you need to buy quality tyres, and not 'el cheapo' ditchfinders
Brains_transit wrote:After seeing vans with the sliding door being bent out from the top I had the idea to slide in reinforcement box section inside the panel so no amount of forcing would make it bend. It's just an idea as no one would touch my van or if they go near it my neighbour warns them to leave
Digrizrat wrote:For winter tyres, I'm on Nokian weatherproof C (the C is for commercial load rated) all season tyre. Done about 20k miles on them, including Norway last Christmas and I'm in Sweden right now.
They're steady enough at 100Mph on the autobahn, though I don't do that frequently, tracking is effortless and straight at 80Mph.
Wear from 10mm to between 8 and 6 mm (the 8mm indicator is gone but the 6mm one is still visible) which I think is pretty good for a winter focused tyre left on in the summer.
Stops fine in the dry (they all do) fantastic in the wet and on ice.
I'll be buying them again
on a 280 125ps btw, with 15 inch steel
ned wrote:Brains_transit wrote:After seeing vans with the sliding door being bent out from the top I had the idea to slide in reinforcement box section inside the panel so no amount of forcing would make it bend. It's just an idea as no one would touch my van or if they go near it my neighbour warns them to leave
Just stick TDCI on the front n back Works for me N
