loot wrote:ned wrote:Bugger off you lot with your bloody air con, just open the window like us tramps do N
Ye yeah you lot get stuffed.......... Oh wait, I also have cold crisp air conditioning in my van, sorry Ned you're on your own mr sweaty crack
Altransit wrote:loot wrote:ned wrote:Bugger off you lot with your bloody air con, just open the window like us tramps do N
I'm actually looking forward to getting stuck on the M25 for an hour, with an outside temp of 35 degrees, like I did last week
Punto443 wrote:And you have to switch off the stop/start as it cuts the A/C out too!
loot wrote:Punto443 wrote:And you have to switch off the stop/start as it cuts the A/C out too!
My stop start doesn't work
bambi mk 1 wrote:loot wrote:Punto443 wrote:And you have to switch off the stop/start as it cuts the A/C out too!
Neds stop start was Fords first attempt on a Transit ,stopped more times than it started
loot wrote:Altransit wrote: I'm actually looking forward to getting stuck on the M25 for an hour, with an outside temp of 35 degrees, like I did last week
After a while when you get chill Blane's on your arms you have to adjust the vents,
dirtydog wrote:I have no air con either
Tango330 wrote:dirtydog wrote:I have no air con either
Don't use my aircon, never have, was always told it used more fuel so just never used it. Mind you, since I fitted the wind deflectors, my normal windows open "aircon" doesn't work either
Betty swallocks or what
Tensioner arrived today, just waiting for new belt.......
loot wrote:bambi mk 1 wrote:loot"quote="Punto443 wrote:And you have to switch off the stop/start as it cuts the A/C out too!
Altransit wrote:I nearly modified the front end of the van, whilst travelling on the slip road, coming off the M25, on to the M40.
A Porsche Cayenne came across in front of me (from the lane to the right), and decided to slam his brakes on, simply because the lane to the right had come to rest due to traffic, and he didn't want to "undertake" even though the slip road was clear, and is a separate lane. I don't normally get caught out by these twats, but that one very nearly had me
Users browsing this forum: Google Adsense [Bot], wardus212
