ake wrote:Brought it home,for the last time, it's getting handed down on Monday.
What's the replacement going to be?. N
loot wrote:steviebee wrote:Its from a Peugeot 307 only 2 wires. An earth and a switched ignition live.
So it has 12v and an ldr that senses bright light and it adjusts it when needed?
I'm still after a mirror with LCD in, I'm currently tracking bjt whereabouts, just hope he hasn't put a rivet in his door lock
EBay 150 pounds
andz327 wrote:loot wrote:steviebee wrote:Its from a Peugeot 307 only 2 wires. An earth and a switched ignition live.
EBay 150 pounds
Is this what your looking for loot
andZ3 Sony Z3
Crankshaft wrote:Finished installing the gas heater as well as the checker plate flooring and carpet lining.
Just need to book some track days to get some use out of it now.
Sent from my SM-G850F using Tapatalk
Crankshaft wrote:Thanks, used 9 cans in total
nedforceone wrote:Made a start on the wiring, just going to lay it out in the van and er-in-doors buggers off out...............................................in the van Bleedin typical. N
andz327 wrote:Crankshaft wrote:Thanks, used 9 cans in total
Did you do both sides doors and roof with 9 cans......
andZ3 Sony Z3
loot wrote:nedforceone wrote:Made a start on the wiring, just going to lay it out in the van and er-in-doors buggers off out...............................................in the van Bleedin typical. N
No no no it's way too tidy, you're clearly doing it all wrong!
nedforceone wrote:
Hay do you like how I used heat shrink on the connectors, am proud of that N
Digrizrat wrote:Did a long highway run, full tank at 70m/h (110km/h) and got 35 miles per gallon (8.1L/100km).
Pretty good for a 2.3 ton camper I think. (MK7 euro5 swb fwd 125ps 280)
