blue estate wrote:All those codes are related to a blanked /non working Egr and are nothing to worry about
hmmm so why my loss of power once the van has warmed up.
I had these codes before the EGR was blanked. and thought that was the reason for loss of power. so blanked the egr. same codes and same problem happening.
Also i dont know if its related. I had a hose go on me the other day. The S shaped hose after the water pump for the coolant. RAC man replaced it with another that really swells up when the accelerator is revved. I thought it swelled up because it was a cheap non genuine one he reaplaced it with. but maybe do you think there could be a blockage after the pump somewhere?
The temperature gauge stays as normal i think. Ill go for a drive in a bit to check
EDIT
So I just cleared the codes, and went for a drive. The codes that re-appeared were p1409 p1402.
And as i said before it was fine until up to temperature then i had the power loss issues. When the largest power loss happened the temperature did move slighly only about 2mm past where the dial sits in the center and only for a second thenthe needle returned to the center of the dial where it usually sits and the power slowly came back :-S
