jumbo55 wrote:2.3 transit lpg 280swb.... now tried every spark plug recommended for lpg, then a mechanic told me i shouldnt be putting platinum or iridium spark plugs into the van... whilst looking on ebay, saw an advert for silver plugs made by brisk, and recommending for the lpg, i reviewed the plugs and it wasnt all positive, but i thought i would try them, i gotta say the van is running the best its ever run. no hesitation, great acceleration, and ticks over really smooth, just thought i would put this on for information, its hard enough to get info on these lpg vans.
M4tty wrote:WARNING: when you fit the New Brisk spark plugs you must check & retune the LPG, GPL or CNG system
as the system will use less fuel with the new correct spark plugs fitted! = Failure to do this will foul the spark plugs & misfire!
you do not need to retune the petrol's injection system on modern petrol injection vehicles as they will self adjust
But on older petrol carburettor engines & non lambda controlled petrol injection system you should
How can the LPG systems ECU be remapped for new plugs. No-one seems to be able to have the software for these necam koltec ecu's?
M4tty wrote:Thanks jumbo I sent them plugs back and exchanged them for the £28 ones so hopefully that may make it run a bit better. Cheers
Users browsing this forum: shonkers
