M4tty wrote:Ive fitted the plugs this morning and the hesitation/flat spot has completely gone. Havent tried running it on gas as yet but will report if its any better. The guy from ebay who i bought them off emailed me after (as i put a link to this forum) and gave the following information which may be useful.
Hi Matthew = Just a quick one on te forum you gave me interestung but a couple things with LPG & Plugs
1 you should never fit platinum or iridium plugs they are no good for LPG & can cause engine & cat damage - infact the only good thing about iridium plugs is they last longer but at a cost even on petrol on economy!
2: never reduce the manufacures gap more than 0.1mm for LPG it can damage the H/T coil/s due to increasing the current, etc... the 0.1mm less gap is just to correct the spark current for LPG which is a dry fuel & petrolis a damp fuel
3: Brisk Silver & multi spark plugs both work A1 in the Transite 2.3i LPG (how to choose! single point type for normal driving - multi point for performance) both give near equal economy!
regards keith
WTV-UK Brisk UK Main Agent
Cheers
Sounds promising.. Be interested in the LPG side obviously..
I sent you a PM about getting the guy from LPG forums down to service my van - you get it .?
