2.4 350 LWB. MK6. Changing fuel filter questions...
Postby Mr Blue » Thu May 31, 2012 12:16 am
Hi all,
I have searched but with no clear answer.
I have a 2005 2.4 350 LWB (mk6) transit and I want to replace the fuel filter as I don't think it has been changed.
Question: Would I need to bleed the injectors when I do this?
How much is the filter from Ford and what do I look out for?
Thanks in advance
Blue :)
Mr Blue
Re: 2.4 350 LWB. MK6. Changing fuel filter questions...
Postby loot » Thu May 31, 2012 8:34 am
There's loads on this mate, they are about 15-25 from Ford, there are about 5 or 6 different ones for tdci and di which ever one should correspond with your vin number, and 2 types of fitment.you will either have a direct screw on filter or a filter that it's held on with a plastic screw on sleeve.
The 2 types i found were the screw on filter was for my non primer pump filter housing, and sleeve type for the primer pump type, you can tell which 1 it will have a button on top.
If you carefully tale off the filter and fool the new 1 full of diesel and replace, it shouldn't need the injectors doing if you have the pump and you bleed it. The non pumping 1 may need bleeding but not necessarily
Ids map here
loot
Postby Mr Blue » Thu May 31, 2012 3:31 pm
thanks for that. It is the 'di'
Another question:
Is this supposed to be full of diesel? Does the mark look ok?
With the engine running it drops lower.
Give me a petrol engine and im fine but i'm new to these Transits :oops:
Mr Blue
Postby loot » Thu May 31, 2012 4:08 pm
I wouldn't worry about that i don't think mine has ever been full,if you change the filter and press reset on it that's pretty much it, if you have the filter primer housing you can bleed any air out before you start the van, i personally have never had any problems changing the filter, just fill it with diesel put it on, press the primer button a few times then while holding it down open the bleed screw then close it then repeat that a few times till no air is present then press reset then start the van up. If it runs then cuts out and won't start then you still have air somewhere and will need to crack the injectors etc :wink:
Ids map here
loot
Postby gNo » Thu May 31, 2012 8:03 pm
I was wary about changing my fuel filter after hearing stories about having to tow vans and bleed injectors but after reading a few posts on hear and following the instructions i had no problems. Just make sure filter is filled to top and keep tapping it to make sure that there is no air trapped in the filter. Start the van and hold revs at 2000rpm for a few minutes, this will get get any air out of the system. Hope this helps.
gNo
Postby Mr Blue » Thu May 31, 2012 9:11 pm
thanks for the confidence boost guys.
Loot I lost you on the bleed screw? (just incase I get int trouble) :lol:
Mr Blue
Postby loot » Thu May 31, 2012 9:29 pm
Lol the housing that has the pump button on top should have a yellow screw on the front, its the bleed, the housing with no pump button doesn't have 1 :D
Ids map here
loot
Postby wexican » Sun Jun 03, 2012 9:29 pm
I find it helps to do it after engine has been running and is still hot!
wexican
Postby Mr Blue » Mon Jul 02, 2012 1:39 pm
Finaly got around changing the filter. filled it with diesel, pressed the reset button,
Fired for a few seconds then died. Battery went flat on trying to start it and guess its got air in the system.
Cracked off the 10mm bleeders and no diesel comes out fo them.
Do you have to keep cranking the engine till diesel squirts out because my battery gives up.
Mr Blue
Postby ake » Mon Jul 02, 2012 2:05 pm
Take filter, off fill with fuel, refit, jump leads to another vehicle, crank for 30 secs, if no joy, remove filter, refill with fuel, refit, crank for 30 secs and repeat till she starts, when she starts hold revs at 2000 for at least one minute.
Do not under any circumstances be tempted to bump or tow start.
2 x 18 Custom 270 Trend
2 x 67 Custom 270 Trend
3 x 66 Custom 270 Trend
1 x 65 Custom 290 Limited
7 x 12 Transit 260 Trend
1 x 60 Transit 350
Or is it something worse?
Postby Mr Blue » Mon Jul 02, 2012 4:42 pm
Thank you for the responce. Yes I read up on bump starting and I have written a warning in the cabin for everyone else to see. :lol:
I did put my industrial mains jump pack on and it did struggle to start due to the air. Also cracked off the 10mm bleeders.
There was air in the system. Took off the filter, filled more diesel, took off the intake pipe and squirted some easy start untill it fired (not reccomended i know)
Held the revs to 2000 rpm and all is good.
Now starts on the first turn of the key. My previous filter was a pattern one (previous owner) and took 2-3 attempts to start.
:D
Mr Blue
Postby ake » Mon Jul 02, 2012 4:43 pm
Well done
1 x 60 Transit 350
Postby APH » Mon Jul 02, 2012 5:14 pm
if you'd crack the 19mm injector feed pipes on top instead of the leak off's (10mm) on the side you would have done it a lot easier :wink:
(\__/)
(")_(")
this is bunny
APH
Postby Mr Blue » Mon Jul 02, 2012 10:12 pm
APH wrote:if you'd crack the 19mm injector feed pipes on top instead of the leak off's (10mm) on the side you would have done it a lot easier :wink:
seized 19mm so left them. Can they pop out complete with the pipes attached?
Mr Blue
Postby Belgaar » Wed Sep 09, 2015 7:56 pm
Thank god this was so much easyer then the wifes Peugeot hahaha
just turn the key 2-3 times for 10 sec and start ;P
The wifes car i had to hand pump so much, i had rubbing wounds on my hands cos they placed that pump in a stupid Place.
had to recharge the battery 3 times and got it started With some help cranking and bleeding ....
Belgaar
