bernies wrote:Right the garage had put washers on the bracket od the vicose fan pulley, now runs a treat but wait for it, the front crank O ring leaking oil, this should of been changed in the first place, not happy, have to wait another day to get my van back, has any body else had this type of experience?
I have just done my timing chain and I had the same problem
After some head scratching if found that the bit the Puley bolts to I changed wen doing the timing kit it is 2mm shorter than the old one so I also put washers behind to sort it out
I had no other choice it was this or stip it all back down removing cover and fitting the old sprocket
I also had a problem with my new tensioner is was made on the wonk so this also threw the belt over so I just removed the wheel from this and placed it on the old tensioner
Hope this makes sense
