Starter Motor Brush Box Replacement
Postby tonyreef » Thu Nov 22, 2012 9:54 pm
Hi Guys,
After having problems with my starter motor, I discovered that the problem was caused by muck inside gunging up the brushes and armature. Since the brushes were fairly worn I replaced them (about £18 off ebay), cleaned the armature and hey presto it now works fine.
What I wanted to share was a YouTube video I came across that shows how to dismantle and replace the brush box. The tip of using a socket to hold back the brushes was a real help!
hope it helps someone.
http://youtu.be/kjBBCpe7aWo
tonyreef
tonyreef
Re: Starter Motor Brush Box Replacement
Postby mr mince » Mon May 20, 2013 1:02 pm
Nice one, knackered brushes seem to be my problem at the moment.
Kicking myself for forking out on new battery first though, suppose I shouldn't grumble too much though as I reckon the Motorcraft one that was in the bus has probably been in there since new.
Diesel smiley lwb minibus running on anything legal, combustable and cheap.
mr mince
Postby vito7304 » Mon May 20, 2013 1:52 pm
used this link to fix my starter its quit informative and as you say the use of the socket is a good idea
vito7304
