Pressure relief Valve
Postby Shafikmiah » Wed Feb 06, 2013 4:46 pm
Hi people, does anyone know if I can buy the PRV on its own for a Mk7 2.2 TDCi? Just been to the dealers and they say I have to by the complete rail which it's attached too??!! £350!!
Cheers in advance.
Shafikmiah
Re: Pressure relief Valve
Postby loot » Wed Feb 06, 2013 7:13 pm
I bought a prv this week on its own they are about 60 quid.
Ids map here
loot
Postby blue estate » Wed Feb 06, 2013 7:18 pm
£58 +£3.25p&p
Genuine Ford Transit 2006 Onwards Fuel Pressure Relief Valve 2.2 2.4 Diesel
£ 66.90 - SOLD (fixed price)
Ended Mon Feb 15th  11:35pm BST
Seller: vospersmotorhouse
mk2.5 Focus zetec 1.8tdci 09 hatch
mk4 Escort estate 1.3no 1.4 yellow
My other car is a 44t MAN TGX 480 tractor unit
blue estate
Postby blue estate » Wed Feb 06, 2013 7:19 pm
Shafikmiah wrote:Hi people, does anyone know if I can buy the PRV on its own for a Mk7 2.2 TDCi? Just been to the dealers and they say I have to by the complete rail which it's attached too??!! £350!!
Cheers in advance.
find another dealer
blue estate
Postby Shafikmiah » Thu Feb 07, 2013 12:40 am
Cheers people, I knew he didn't seem sure himself when he was quoting me.
Thanks for help
Shafikmiah
Postby Shafikmiah » Thu Feb 07, 2013 12:42 am
blue estate wrote:£58 +£3.25p&p
Your a star! Cheers
Shafikmiah
Postby fedup2 » Thu Feb 07, 2013 11:28 am
Ive had a couple over time from Ebay,the last one was £20.I always keep one in for a rainy day.
Launch x431 owner ;)
fedup2
Postby Shafikmiah » Thu Feb 07, 2013 12:50 pm
fedup2 wrote:Ive had a couple over time from Ebay,the last one was £20.I always keep one in for a rainy day.
I've ordered one from the link above. Just been trying to get the old one off this morning, but it's not budging! Is it normal to be this tight and would a little WD40 help it along?
Cheers
Shafikmiah
Postby loot » Thu Feb 07, 2013 12:54 pm
It is tight, if it helps take the rail off and put it in a vice.
Ids map here
loot
Postby fedup2 » Thu Feb 07, 2013 12:55 pm
They are always tight.Use a long extension on a spanner and give it a sharp jolt.It will go.
fedup2
Postby Shafikmiah » Thu Feb 07, 2013 1:07 pm
fedup2 wrote:They are always tight.Use a long extension on a spanner and give it a sharp jolt.It will go.
Cheers buddy. Thanks for the quick reply!
Shafikmiah
Postby Shafikmiah » Thu Feb 07, 2013 1:12 pm
loot34 wrote:It is tight, if it helps take the rail off and put it in a vice.
Looks like I'm going to have to. Cheers
Shafikmiah
Postby Shafikmiah » Thu Feb 07, 2013 4:33 pm
Got it off finally!! Quick question lads? The old didn't come off with a washer? Any ideas which side the new washer will go? Fuel rail side or leak off pipe side?
Cheers
Shafikmiah
Postby loot » Thu Feb 07, 2013 7:24 pm
Look inside the rail the washer will be in there, there is a thin 1 for in the rail and a thicker 1 for the other end, when refitting the pipe end doesn't want over tightening, ideally get it torqued up properly.
8)
Was the prv exploded when you removed it btw?
Ids map here
loot
Postby Shafikmiah » Thu Feb 07, 2013 9:32 pm
loot34 wrote:Look inside the rail the washer will be in there, there is a thin 1 for in the rail and a thicker 1 for the other end, when refitting the pipe end doesn't want over tightening, ideally get it torqued up properly.
8)
No the old one came out in one piece but I've replaced it anyway. I bought and installed the leak off pipe too, it was cheap enough. It's my last attempt to try and fix this hunting, stalling and power holding back at 1500rpm. Numerous post on here have suggested PRV and PCM update so I'm going with that. Changed EGR, changed Fuel filter housing because of air in the clear fuel pipe and cleaned MAF sensor but the problems ain't gone. Hope this attempt works.....
Shafikmiah
