Do all mk7 have an auxiliary battery?
Postby Surfunitone » Tue Mar 12, 2013 6:13 am
Also are the batteries connected via a charging relay? If I connect an inverter to the aux will it drain the main battery?
I have ps110 2.2
2.2 Duratorq-TDCi (110PS)
Surfunitone
Re: Do all mk7 have an auxiliary battery?
Postby motorman116 » Tue Mar 12, 2013 7:37 am
From what I understand as its been mentioned on here a number of times, is that its only the rear wheel drive Transits that have dual batteries, and they are fitted via a split charge relay
2008 3.2 5 pot diesel Ford Transit GLX Lwb, Hr
motorman116
Postby ake » Tue Mar 12, 2013 8:14 am
Twin batteries standard on rear wheel drive Mk 7 and optional on front wheel drive.
2 x 67 Custom 270 Trend
3 x 66 Custom 270 Trend
1 x 65 Custom 290 Limited
7 x 12 Transit 260 Trend
1 x 60 Transit 350
Or is it something worse?
Postby Surfunitone » Tue Mar 12, 2013 9:31 am
Thanks for your replies. i'll have to venture out into the cold and have a look :) I'll let you know what i find :)
Surfunitone
Postby Guy88 » Tue Mar 12, 2013 10:53 am
if you hear a loud click when you turn the ignition on you have twin batteries
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby fedup2 » Tue Mar 12, 2013 10:54 am
The higher specced FWD have 2 batteries.
invertor wiring..........
left is rear.
Launch x431 owner ;)
fedup2
Postby belly » Tue Mar 12, 2013 11:15 am
fedup2 wrote:The higher specced FWD have 2 batteries.
left is rear.
Not all of them.
belly
Kaiser Chief
Postby fedup2 » Tue Mar 12, 2013 11:22 am
i dunno mate to be honest.Suppose the way to check without getting cold is here.....
http://www.etis.ford.com/vehicleRegSele ... B.fcvas510
fedup2
Postby HARRYSPADGE » Tue Mar 12, 2013 2:00 pm
Surfunitone wrote:Also are the batteries connected via a charging relay? If I connect an inverter to the aux will it drain the main battery?
I have ps110 2.2
As I understand it, when the ignition is OFF the aux and main batteries are separated by the split charge relay so that you can run auxiliary items like interior lights, radio, etc. without the risk of running the main (starter) battery flat.
So,in answer to your question, if you connect an inverter to the aux battery you will not drain the main (starter) battery.
HARRYSPADGE
Postby Surfunitone » Tue Mar 12, 2013 2:05 pm
Cheers everyone!!
Surfunitone
Postby ake » Tue Mar 12, 2013 9:10 pm
I have ps110 2.2
But only if you have 2 batteries !!!!!
1 x 60 Transit 350
Postby ake » Tue Mar 12, 2013 9:11 pm
left is rear.
Not all of them.
Only if specified as an extra. Even limited and Chav spec only have one as standard.
1 x 60 Transit 350
Postby Honey monster » Tue Mar 12, 2013 9:24 pm
I have ps110 2.2
I had an ex BT Mk6 and the batterys where just connected in parallel, I take it this was a different set up than the one you mention above. :? :?
Honey monster
Postby ake » Tue Mar 12, 2013 9:34 pm
Honey monster wrote:
I have ps110 2.2
Yes the mk7 setup has a disconnect relay that separates the batteries at key off. The Mk 6 setup was just two batteries permanently linked together.
1 x 60 Transit 350
Postby Honey monster » Tue Mar 12, 2013 9:39 pm
Sorry Ake bare with me, So If I want to add another battery to my Mk7 (Only one batt now) to use as aux when engine is off I will have to add a disconnect relay??
Honey monster
Users browsing this forum: wurzel
