ok so the above pic might not have uploaded!
so the sliding door works from the inside but the out side handle only works if i am VERY careful...
when i look inside the door (from the inside of van) there is two plactic levers... the bottom lever pulls a metal latch which is connected to cable via a orange clip
the problem is that there is nothing catchin the top lever which moves when outside handle is pulled.... i figure there must be something missing
anyone have any ideas? there must be something that connects from bottom lever to top lever!
If it aint nailed down... sling it in da van
