How much should side loading door open
Postby Harley59 » Sun May 12, 2013 7:29 pm
My 2003 transit minibus sliding door only opens half way before door stop at the top hits the side of van stopping it open fully. The runner for sliding door runs along side of van almost to the rear. Am i missing something and it should open fully. Also there is only 1 rubber stop ob doir which is bolted to top. Should there be 1 in the middle
Harley59
Re: How much should side loading door open
Postby blue estate » Sun May 12, 2013 7:32 pm
Mini bus side doors don't open fully due to the step :wink:
blue estate
Postby Harley59 » Sun May 12, 2013 7:55 pm
Thanks very much. That was so quick to answer. Do u know about adjustment? I pulled in bottom of door on bottom slider but then it hit the two stops on slam post. Do i have to let top runner out, im worried that if top of door sticks out rain will come in. Should i try to adjust or leave well alone
Thanks in advance
Harley59
Postby wexican » Mon May 13, 2013 11:19 pm
Harley59 wrote:My 2003 transit minibus sliding door only opens half way before door stop at the top hits the side of van stopping it open fully. The runner for sliding door runs along side of van almost to the rear. Am i missing something and it should open fully. Also there is only 1 rubber stop ob doir which is bolted to top. Should there be 1 in the middle
Yes
should be one in the middle. As for adjustment leave well enough alone if its reasonably flush. should be 6mm all round AFAIK.
wexican
Postby Harley59 » Tue May 14, 2013 9:41 pm
Would it do anyharm to remove stops completly so door opens fully?
Harley59
Postby wexican » Wed May 15, 2013 10:46 am
Doesn't the lower roller location prevent it sliding back fully anyway?
It is bolted to the middle of the door rather than the leading edge so don't think it'll work
wexican
Postby Harley59 » Wed May 15, 2013 11:05 am
No i only have one bumper stop bolted top middle of door. The one that is in the middle is missing ?
Harley59
Postby catmangler » Fri May 17, 2013 3:16 pm
The doors were restricted BECAUSE they have seats there. It's to prevent folks falling out.
Yes, you COULD take the stops off, they only bolt on after all, but may be sued if anyone is hurt...
If you have twin doors, it's NOT a Ford interior, but a conversion with Ford approval. Bit like the tippers.
I wrote the book, once.
catmangler
Postby wexican » Sun May 19, 2013 10:40 pm
catmangler wrote:The doors were restricted BECAUSE they have seats there. It's to prevent folks falling out.
Its also to stop folk gawping in at the dude on the single seat by the door. LDV's used to have a "modesty panel" by the seat there :P
wexican
