Damien89 wrote:Common problem because the vans are so air tight, lower one of the front windows 1/2 way and it will close with ease, otherwise you will need to slam it.
loot34 wrote:I thought the vent under the sliding door stopped this?
Guy88 wrote:Never heard of a transit being air tight.
The minibus windows leak enough to let the air out.
Try adjusting the striker plate further out
Damien89 wrote:Guy88 wrote:Never heard of a transit being air tight.
If he adjusts the striker plate the whole door wont seal properly and water could get in.
I know it for a fact because here in malta we have loads of minibuses and everybody has this problem. Small kids sometimes cant close the door properly because of this problem. Try lowering one of the front windows half way down and see if it solves you problem.
