Mk6 2.4 piston & ring variations ????? Help required
Postby TRS » Wed May 15, 2013 4:47 pm
Hi all,
I'm doing a full rebuild of my 125 2.4 TDDI engine. I'm part way through the build and took delivery of the pistons rings earlier this week. When I ordered the rings from a well established local engine builder he asked me for the size of the rings. Obv a fare question. I picked up the piston and measured the thickness with a vernier.... top ring was 2mm thick, 2nd ring was also 2mm and the 3rd oil ring was 3mm. All the rings he supplied were correct. Fitted piston No 1.....perfect. Selected piston No2......top and 2nd ring on and came to the oil ring and......oh.....way too large..... :? Strange, checked all the rings again and it would appear I have 1 spurious piston. The other 3 pistons (2,3,4) all have 2mm thickness rings however number 1 has a thicker oil ring (3mm) I can get the other rings swapped by my supplier but I'm inquisitive as to why this is. Possibly in its previous life it been rebuild with an oddy as I'd say or it rolled out the factory like this. My main concern is the now inserted piston No1 has a larger oil ring with larger holes in the ring than the other bores. Oil pressures etc be off as surley they should be equal. Does anyone know of which is correct for that engine or .....??? Any info would be great. Cheers.
TRS
Re: Mk6 2.4 piston & ring variations ????? Help required
Postby TRS » Fri May 17, 2013 9:30 am
Anyone????? any idea why there is a 3mm and a 2mm oil ring??? later or earlier engines???
TRS
Postby belly » Fri May 17, 2013 9:55 am
Tdci piston maybe ? People have mentioned the Tdci has under piston oil spray cooling so potentially differ ?
belly
Kaiser Chief
Postby TRS » Fri May 17, 2013 12:23 pm
well that has thrown me then as mine is the TDDI but has under piston cooling?? :?
TRS
Postby bambi mk 1 » Fri May 17, 2013 8:36 pm
There are a few types of pistons.Check if the bowl is the same size.Also make sure all the bores are the same size as it is not uncommon for one to be oversize .Some people will bore just the damaged cyl when the piston cracks .Will run ok that way.
bambi mk 1
Postby TRS » Sun May 19, 2013 9:30 pm
Yeah all bores are the same size and checked all ring end gaps etc I'm just cautious to running 1 piston with a bigger oil ring ?? :?
TRS
Postby bambi mk 1 » Sun May 19, 2013 9:48 pm
You wont have any problems ,had a few that way ran ok.
bambi mk 1
Users browsing this forum: Google [Bot], Liska
