4 loudspeakers on Mk7 Motorhome coding via OBD
Postby slk-A4 » Sun May 19, 2013 2:40 pm
Hi folks,
in my Mk7 Motorhome 2.2 TDCi 130 HP I´ve added two loudspeakers at the rear. The van is equipped with a 6000CD radio, that has on the front a balance/fader button. The new loudspeakers work, although the front loudspeakers are a bit louder. On a campsite, I want to switch off the front loudspeakers, because they are in the frontdoors and therefore they could annoy other campers.
As you can guess, this button on the 6000CD doesn´t work. I´ve read here and there, that in motorhomes often the rear loudspeakers are switched off via canbus.
I own the OBD interface Ross-Tech VAG-COM (VCDS), with which I can scan the motomanagement, I can reset the MIL and do some scanning with it, but I can only address the motormanagement.
This it states:
Mode 9 : Calibration Identification
Type 02 - VIN : WF07XXTTF77U86777 (Address E8)
Type 04 - Calibration ID : 6C11-12K532-KS (Address E8)
Type 06 - Calibration Verification Number : 00008E3C (Address E8)
I cannot myself get into the rest of the canbus with this interface, or at least, i haven´t found out, how to do it untill now.
Do I have to go to the dealers to unlock this feature or does anyone know a trick, perhaps the address of this feature, so I could get into the canbus with my VAG-COM interface? :?: :?:
Ford Transit 2.2 TDCI 140 BHP Camper Chausson Flash 22 2011
slk-A4
Re: 4 loudspeakers on Mk7 Motorhome coding via OBD
Postby blue estate » Sun May 19, 2013 2:46 pm
Go on flea bay and get one thats come out of a car the fader will be switched on and flogg off your one
Ford sony one will fit like thishttp://www.ebay.co.uk/itm/FORD-SONY-CD- ... 4d0ca07e52
or thishttp://www.ebay.co.uk/itm/Ford-Mondeo-M ... 27d2da9d14
blue estate
Postby blue estate » Sun May 19, 2013 3:02 pm
Just to comfirm my sony gen 2 ford head that came out a focus , the fader works :wink: so as long as you get one from a car not van then the fader will work
blue estate
Postby slk-A4 » Sun May 19, 2013 3:05 pm
thanx for your answers, but BEMM states, it just needs recoding, that will be cheaper than buying a new one. Can anyone confirm the coding via IDS or, as I asked, via OBD`?
slk-A4
Postby blue estate » Sun May 19, 2013 3:12 pm
slk-A4 wrote:thanx for your answers, but BEMM states, it just needs recoding, that will be cheaper than buying a new one. Can anyone confirm the coding via IDS or, as I asked, via OBD`?
But you will get better sound from the ford sony one :wink:
And yes it is via ids
blue estate
Postby slk-A4 » Sun May 19, 2013 3:41 pm
This is what BEMM says:
Additional Rear Speakers Camper vehicles,
typically, are only equipped with speakers in the
front doors, in which case at end-of-line the vehicle
will be programmed for just the front speakers and
the fade function disabled on the radios. If the
radio is set for four speakers, and those at the rear
are absent, a fault code will be flagged. The vehicle
would need reconfiguring at a Dealer once
speakers are installed. The radio will output 17W
per channel (left and right); a wire size with a CSA
of 0.75 is recommended.
On camper vehicles, a camper rear speaker signal
connector is located in the seat pedestal.
slk-A4
Postby apples26 » Sun May 19, 2013 4:01 pm
I've got a Sony one with code that's from a 08 fiesta that might be spare v soon
http://WWW.NEEDATOW.CO.UK
apples26
Postby ake » Sun May 19, 2013 6:46 pm
Anyone with access to Ford ids can reprogram it, either a Ford dealer, or a good independent .
Postby shovelheadrob » Sun May 19, 2013 8:34 pm
When I fitted rear speakers to mine we just connected to the rear speaker connections in the multi plug coming from the head unit & it all worked fine, didn't need any coding or hooking up to ids, maybe I was lucky!
Panther Black 2012 155ps 350 LWB Limited with extra toys
Leather, reversing camera, dual side doors, LED DRLs
shovelheadrob
Postby Timbo » Sun May 19, 2013 8:37 pm
Then you can set the Fader to REAR and it will silence the front speakers.
Timbo
Postby slk-A4 » Sun May 19, 2013 9:45 pm
my problem is that my van is a motorhome, as I wrote before, and these usually are fitted with only two front speakers. The fade function of the 6000CD has been disabled at the factory. The balance-fade button on the radio is only for balance, fade does not work. SO I will have to go to dealer.
slk-A4
Postby apples26 » Sun May 19, 2013 9:49 pm
I think would be easier to just upgrade the radio for a used one from ebay
apples26
Postby Hugh Jampton » Sun May 19, 2013 10:25 pm
Whilst I can't help you with the details of the process, I can confirm that the information in the BEMM is correct.
My Mk7-based motorhome was supplied with 4 speakers as standard, but the fader was disabled.
It was subject to the intercooler recall from scratch, and I asked my dealer to look at it (with the BEMM wording as reference) whilst doing the recall work.
Whilst they professed no knowledge, it was delivered back to me with the fader working, and a "smiley" on the worksheet.
FOC as well!
HTH
Hugh Jampton
Postby slk-A4 » Tue May 21, 2013 5:39 pm
Could anyone who is familiar with IDS please post how this is done in IDS?
(I mean step by step).
Thanx!
slk-A4
Postby ake » Tue May 21, 2013 5:45 pm
slk-A4 wrote:Could anyone who is familiar with IDS please post how this is done in IDS?
Thanx!
Enter module programming
Enter configurable parameters
Download configuration file
Alter no of speakers to 4
Upload configuration file
Job done
