EGR blanking, what happens next
Postby limitedblack » Tue May 21, 2013 4:25 pm
Well there must be a dozen topics on this, and plenty of pros/cons lists, but I was just wondering, what happens on the exhaust side of the EGR valve once it is blanked. Being a plumber (allegedly), its always a bad thing to have a "dead leg" in pipe work, and as the mk7 has a fairly long run to the valve then this can't be good can it? Anyone taken bits off after a blanking, or had any issues other than MIL lights due to its blocking? :-|
Happy Easter
limitedblack
Re: EGR blanking, what happens next
Postby belly » Tue May 21, 2013 6:52 pm
Ok not a mk7 but my old mk6 jumbo was blanked the first week I bought it and is still blanked to this day (mate bought it) four years on iirc, no issues still goes like a train and its the "fussy" 135 8)
belly
Kaiser Chief
Postby limitedblack » Tue May 21, 2013 7:06 pm
belly wrote:Ok not a mk7 but my old mk6 jumbo was blanked the first week I bought it and is still blanked to this day (mate bought it) four years on iirc, no issues still goes like a train and its the "fussy" 135 8)
So not done it on the MK 7 then ?
Happy Easter
limitedblack
Postby g-man » Tue May 21, 2013 7:08 pm
blank it on the manifold then if you're concerned
g-man
Postby belly » Tue May 21, 2013 7:11 pm
Vantuner has switched my egr off :wink: I waited for him to do it so the mil doesn't come on :D
belly
Kaiser Chief
Postby blue estate » Tue May 21, 2013 7:40 pm
belly wrote:Vantuner has switched my egr off :wink: I waited for him to do it so the mil doesn't come on :D
Mine has been done as well but i've also blanked it as it gave up the ghost last week
blue estate
Postby limitedblack » Tue May 21, 2013 8:12 pm
It's just one of those things seems too good to be true, got one ready, just looking for any "bad" feedback.
Happy Easter
limitedblack
Postby belly » Tue May 21, 2013 8:41 pm
Have you whipped off your inlet yet Limbak ?
belly
Kaiser Chief
Postby limitedblack » Tue May 21, 2013 8:49 pm
Nope, 24k suppose its time. TBH I get times when I don't want to touch the van, then I will have a splurge on it, now isn't the time ;)
Happy Easter
limitedblack
Postby belly » Tue May 21, 2013 8:53 pm
Ditto :wink: Mine is filthy with the front covered in paste from parking tight to a panel but all I want to do is lock it and leave it :lol: Mine was pretty gooed up :roll:
belly
Kaiser Chief
Postby 2ndclasscitizen » Tue May 21, 2013 9:54 pm
Talking about inlets... Mine is really, really bad, so are the ports on the head. Is there any risk if I try scraping all the crap out of the ports? Or if anything falls in and gets past a valve will it just be burnt up in the combustion process?
To be old and wise you must first be young and foolish.
2ndclasscitizen
Postby limitedblack » Tue May 21, 2013 9:57 pm
2ndclasscitizen wrote:Talking about inlets... Mine is really, really bad, so are the ports on the head. Is there any risk if I try scraping all the crap out of the ports? Or if anything falls in and gets past a valve will it just be burnt up in the combustion process?
I thought that, but then bits must break off anyway, so it's already eating them now :o
Happy Easter
limitedblack
Postby limitedblack » Fri May 24, 2013 5:08 pm
So moving on, when blanking the EGR, don't you need a second gasket to seal both sides of the plate?
Happy Easter
limitedblack
Postby belly » Fri May 24, 2013 5:11 pm
limitedblack wrote:So moving on, when blanking the EGR, don't you need a second gasket to seal both sides of the plate?
I never did on the mk6's remember it will through the mil light on unless you get Vantuner to sort it :wink:
belly
Kaiser Chief
Postby limitedblack » Fri May 24, 2013 5:13 pm
Still drives ok though other than the light ?
Happy Easter
limitedblack
