Gear selector cable
Gear selector cable
Postby exarmyjedi » Tue May 21, 2013 6:59 pm
Guys i want to make my gear change a bit tighter as it seems to be 'loose' and sometimes crunching into gear unless i really force the stick towards the gear, how would i adjust the selector cable?
In advance thanks guys :) :) :)
exarmyjedi
Location: N.Ire mountain man where the men are men and the sheep are scared!!!
Re: Gear selector cable
Postby snowballer » Tue May 21, 2013 8:52 pm
under the van below gearstick there's a black box unclip and you then see the cables..
snowballer
Postby exarmyjedi » Tue May 21, 2013 9:04 pm
Cheers, i got that ok but how are they adjusted?? is it allen key, spanners?? thanks again :) :)
exarmyjedi
Postby 2ndclasscitizen » Tue May 21, 2013 10:05 pm
Fit a M10 X 30MM bolt into the hole through the cable mounting as shown to lock the gear leaver in to neutral.
Once the gear leaver is locked you then need to remove the 2 metal clips on each cable and then push forward the black plastic piece that the clip is holding on.
Adjust the cable, push the black plastic piece back again, replace the clip, take out the bolt and check the gears.
Have you also checked the bolt on the selector?
To be old and wise you must first be young and foolish.
2ndclasscitizen
Postby exarmyjedi » Wed May 22, 2013 6:16 am
2ndclasscitizen wrote:Fit a M10 X 30MM bolt into the hole through the cable mounting as shown to lock the gear leaver in to neutral.
Thanks for this!!!!!! perfect step by step guide....... as per usual.... if carlsberg did transit forum members.... it would probably be you lads
Thanks again!!! :D :D :D
exarmyjedi
Postby tomo320 » Thu May 23, 2013 2:54 pm
That's a really helpful guide that mate.
tomo320
