Hi everyone. Unfortunately, this isn't a transit as such, although I have got a MK6. It is a 2008 Citroen Relay of mine, which uses the 2.2 TDCi engine. It is very poorly at the minute, and I was wondering if anybody could point me in the right direction.
When you first start it, it misfires like hell, and bellows white/light grey smoke (which has a tinge of blue to it), when I say bellows, I mean fills the street. Once warm, the misfire disappears BUT the smoking continues, sometimes it will disappear for a mile, but then return.
So far, I think I can rule out the turbo, as when I disconnected the intercooler pipes, no smoke came through them and the van continued to smoke from the exhaust as normal. Also, the van doesn't appear to be using any water.
I feel this leaves me with 3 or 4 options, and i'm hoping somebody can point me in the right direction.
1- Could it be a duff injector/s overfueling? but then why the blueish tinge?
2- Could the valve seals be shot?
3- Could the rings be drawing oil in?
4- Could the head gasket have failed?
I appreciate its just guesswork for you lot, but hopefully the symptoms may corresspond to something somebody else has had problems with.
Also, if it was an injector, is the Ford IDS programme available to download to a laptop for use with an OBD socket?
Cheers.
Rhys
