Air con compressor
Air con compressor
Postby Guy88 » Sun Mar 04, 2007 5:55 pm
After a cheap AC compressor and bracket to fit it to a Di :D
2005 Ford F250 Super Duty
1974 MK1 V8 ex camper
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby madmark » Sun Mar 04, 2007 7:43 pm
:shock: :shock: :shock: :shock:
Postby AndyG » Mon Mar 05, 2007 12:42 am
Guy88 wrote:After a cheap AC compressor and bracket to fit it to a Di :D
madmark wrote::shock: :shock: :shock: :shock:
Did you get a chance to look at how it was fitted on mine :?:
Postby gemini » Mon Mar 05, 2007 12:45 am
Andyg wrote:Did you get a chance to look at how it was fitted on mine :?:
is yours still there :shock:
gemini
Postby AndyG » Mon Mar 05, 2007 1:03 am
gemini wrote:is yours still there :shock:
Was, when I last looked :!: :shock:
Don't make me go out and have a look :!: It's late :!:
Did you have it Guy88 :?: :shock:
Postby gemini » Mon Mar 05, 2007 1:07 am
Andyg wrote:Don't make me go out and have a look :!: It's late :!:
gets his boots on :lol:
gemini
Postby Guy88 » Mon Mar 05, 2007 9:37 am
Tempted but i didnt. :shock: :shock:
I think somone would have noticed :lol:
Im arfer any old compressor and a bracket i can use to fit it to a Di.
Andy i didnt think of looking at yours :roll: I assume it moves the PAS pump and bolts on there :?
1984 A series RB44
LIVIN' LOUD
Guy88
Postby MrMPuk » Mon Mar 05, 2007 2:08 pm
Guy88 wrote:Andy i didnt think of looking at yours :roll: I assume it moves the PAS pump and bolts on there :?
No the AC compressor goes lower down.
Postby Luke » Mon Mar 05, 2007 7:47 pm
what you after compressed air or air con :?:
Postby madmark » Mon Mar 05, 2007 7:52 pm
:shock: i certanly wouldnt fancy fitting aircon! :shock: :shock:
Postby Guy88 » Mon Mar 05, 2007 8:07 pm
Compressed air :wink:
Looked for an old lorry pump but can only find ones that sandwich between the Fuel pump :(
I am thinking of an AC compressor to fill a tank to a set pressure then a relief valve to cut the clutch off. Also will have a switch on the dash so its only on when its needed 8)
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Mon Mar 05, 2007 8:09 pm
what do you think the max pressure will be on an air con pump :? :?:
Postby Guy88 » Mon Mar 05, 2007 8:11 pm
Im not really sure of pressure but they have one hell of a flow
1984 A series RB44
LIVIN' LOUD
Guy88
Postby MrMPuk » Mon Mar 05, 2007 8:19 pm
I wouldn't bother Guy, it wont last 5 minutes with out the oil that is in the AC system.
Postby Luke » Mon Mar 05, 2007 8:19 pm
Guy88 wrote:Im not really sure of pressure but they have one hell of a flow
i presume you want it for air tools :?: i had this idea for my mates van - mobile spray painter, but i thought it would be no good if it maxed out at 35 psi :lol:
no idea what it does make tho - didnt get that far :lol:
