Ber-Tech wrote:cheers t2myd will have a go - gently gently
remind me when i'm finished to write a strongly worded email to ford gearbox design department and give them a couple of tips.....
blue estate wrote:Well just come across this thread as i'm about to do my slave cylinder but also doing my clutch as well as vans done 110k parcel work and it judders in reverse
t2myd wrote:blue estate wrote:Well just come across this thread as i'm about to do my slave cylinder but also doing my clutch as well as vans done 110k parcel work and it judders in reverse
Blue estate where are you in this country , I've a ex ford mechanic who can do these on less than 2 hours
smily325 wrote:hello any one no if 6 speed box will fit in place of 5 speed mk 7 rwd and does any one have a box ether sort . ??
smily325 wrote:how do you check duel mass flywheel for wear ??
t2myd wrote:smily325 wrote:hello any one no if 6 speed box will fit in place of 5 speed mk 7 rwd and does any one have a box ether sort . ??
The box will fit but clutch / flywheel is different , , if your just going to change the box there won't be any difference
