Recall 155ps not sure about which others are affected.
Postby shovelheadrob » Mon Dec 23, 2013 4:00 pm
Just booked my van in for second service & it's due a recall update. Haven't had the letter from Ford yet but the dealer showed me their notification. At low engine temperature, below 20°c excess cylinder pressure can cause piston cracks or failure. Be interesting to see it this stops it sounding like a bag of nails when it's cold!
Panther Black 2012 155ps 350 LWB Limited with extra toys
Leather, reversing camera, dual side doors, LED DRLs
shovelheadrob
Re: Recall 155ps not sure about what others are affected.
Postby Mike » Mon Dec 23, 2013 4:02 pm
shovelheadrob wrote:Just booked my van in for second service & it's due a recall update. Haven't had the letter from Ford yet but the dealer showed me their notification. At low engine temperature, below 20°c excess cylinder pressure can cause piston cracks or failure. Be interesting to see it this stops it sounding like a bag of nails when it's cold!
Does the recall show up in etis?
Mike
Wind up merchant!
Re: Recall 155ps not sure about which others are affected.
Postby shovelheadrob » Mon Dec 23, 2013 4:08 pm
I don't know Mike, just tried but it wouldn't work with my reg no. I'm away for Christmas so don't have the vin handy.
shovelheadrob
Postby Mike » Mon Dec 23, 2013 4:12 pm
Shows this, "Outstanding Field Service Actions 3S548 - TRANSIT 2.2LTR - PISTON - SOFTWARE"
Mike
Wind up merchant!
Postby shovelheadrob » Mon Dec 23, 2013 4:17 pm
That was the title of the bulletin they showed me IIRC. Does that apply to yours too?
shovelheadrob
Postby Mike » Mon Dec 23, 2013 4:19 pm
shovelheadrob wrote:That was the title of the bulletin they showed me IIRC. Does that apply to yours too?
No, must be purely a software issue.
Mike
Wind up merchant!
Postby V184 » Mon Dec 23, 2013 5:55 pm
Oh fu-k mine needs doing, means i will get it back & it will hunt on tickover & proberly have about 100 horses ( sorry moved the torque curve :twisted: ) Im gutted :cry: :cry: :cry: :cry:
V184
Postby shovelheadrob » Tue Dec 31, 2013 9:43 pm
Well they did the service & software update today & the first things I've noticed are the idle speed has increased to around 950rpm, the anti stall seems a bit more noticeable & driving it home it seemed a bit quieter, I'll see if it's any different from stone cold tomorrow. No difference in normal driving power wise, I'm going to get in touch with Martyn (Vantuner) let him work his magic now it's well run in!
shovelheadrob
Postby shovelheadrob » Fri Jan 03, 2014 11:16 pm
Went out in the van today, from stone cold it is the quietest it's ever been even with the sounds off there is no diesel knock at all, smooth to. Back to work on Monday so next week will see if the economy has changed. Still not had a letter from Ford about it......strange!
No one else had a notification then?
shovelheadrob
Postby shovelheadrob » Thu Jan 09, 2014 7:46 pm
V184 wrote:Oh fu-k mine needs doing, means i will get it back & it will hunt on tickover & proberly have about 100 horses ( sorry moved the torque curve :twisted: ) Im gutted :cry: :cry: :cry: :cry:
Did you get yours done? My fuel consumption has improved quite dramatically, before service I was getting 29.8mpg according to the trip computer, this week on the same run it has averaged 34.7mpg.
shovelheadrob
Postby Mike » Thu Jan 09, 2014 7:57 pm
Wow, I could do with an mpg increase like that.
Mike
Wind up merchant!
Postby shovelheadrob » Thu Jan 09, 2014 9:55 pm
I'm going to work it out on paper at the weekend, just in case the computer calibration has changed, as before the service the trip consumption was always 1-2mpg lower than I calculated.
shovelheadrob
Postby Mike » Thu Jan 09, 2014 9:57 pm
I use an app called Road Trip LE which works out mpg for you, I've been using it for 20k miles now and the readings are always very close to the van readout.
Mike
Wind up merchant!
Postby V184 » Fri Jan 10, 2014 11:34 pm
Not yet, im on 96k so will sort next week :)
V184
Postby DynamicAV » Sat Jan 11, 2014 10:53 am
Just seen this and spoken to my dealer......service guy there didnt know anything about it but its now booked in as it is outstanding.
Asked them also to look at the problem that when you leave the hazard lights on for any period when you get back in the van you have no lights or control of the stereo until you leave the van all switched off for 30 mins.
T350 LWB HR 155 Limited in Midnight Sky
Old - T350 LWB HR 140 Magnum Grey
DynamicAV
