ake wrote:loot wrote:I found 1 on my loom so moved on
I think i have a spare if you are stuck mate
If i was a bit desperate tho I'd just use 2 small ends from the bcm pin connector and squirt a blob of silicone in the hole i think, or black sealant and i have large heat shrink I'd put over the top to make it nice
Sealant should be non conductive i would think.
Let me know if you want the end and I'll see if i can find it/post it on Monday
Silicon based sealant is non conductive and will work fine, but some others conduct as they are water based
Some silicone sealants release acid which will destroy electrical connectors, you have to get one that is electrically safe.
