Hi Gents, I have researched and researched and I need a favor from you lucky 200PS transit owners.
I live in Australia and unfortunately we did not received any Mk7 200PS 3.2L 5cyl transits here. This engine is new to us and we are only starting to see it used in the 2012 to 2014 ford ranger XLT 4x4 and 4x2 utes.
I have read on the forums that the 200PS transit chassis are 4 inches longer than the MK7 140PS chassis and that the extra length comes from extensions that bolt onto the front chassis rails. this also requires a different front bar which is visibly noticeable.
What I would like to know is the engine bay depth (front to back)(firewall to radiator support) and dimensions of bonnet and quarter panels to check if they are the same items as the 140PS Mk7 cab chassis transits we have in Aus or are they in fact different, and if they are different dimensional how much by.
What I plan to do is to buy a ford ranger 3.2L 5cyl from the wreckers and transplant engine and ECU / wiring looms and patch them into the Transit. The gearbox is still unknown territory at this stage but it will be a modified / welded bell housing to use the existing 140PS transit gearbox or use matching ranger gearbox.
I have taken lots of other dimensional measurements which will allow me to check the ford ranger engine and engine mount compatibility.
Before anyone harps on about how much work this will be, I am skilled enough in metal fabrication, welding and electrical experience. I have at my disposal all workshop fabrication equipment to preform all modifications in house. If this project was to go ahead all stages would be fully transparent on the forum for all members to view.
Would a member of a 200PS transit be able to take the following measurements and post results so we all know the dimensional differences between the rare 200ps powerhorse and the common 140ps transits
Photos below...
Firewall to radiator support panel: dimension 700mm
Bonnet top to bottom: dimension 575mm
Quarter panels: dimension 700mm
