loot34 wrote:I had the fuel rail off, the injectors pipes off, the prv off, the scv off.
Put it all back together and simply turned the key to start, took roughly 8-10 seconds and it burst into life, revved it for a bit and that was it.
loot34 wrote:You get upto 3 tries as stated by ids, you sometimes have to try again, try injector learn then try pump learn again, that's what i had to do anyway lol.
Glad you sorted it
loot34 wrote:Ids isn't limited to 3 pump learns but it does say after 3 it needs fixing.
loot34 wrote:If the injectors aren't learning is probably fluctuating engine/fuel but if you replaced prv/scv then there must be another problem, ids does say 1/4 tank of fuel.
loot34 wrote:Good batteries may or may not help.
Could try blanking the egr, mine learnt straight away with it blanked but when i took the blank out is when it took a couple of goes
I forget, did you do a leak off on the injectors?
martynx wrote:Have you reset the Prv counters Dave ?
v8dave wrote:martynx wrote:Have you reset the Prv counters Dave ?
Martyn, thanks for that suggestion - i'll try that.
Is there a way of reading the prv count or duration if they are set ?
Shouldn't there be a dtc if they are set ?
I'm going to try a suggestion from Loot in another thread of doing injector learn then pump but since that puts the operations out of sequence ?
There is also a newer calibration which I've down loaded from motorcraft but I can find out if I need to unzip the file. IDS calibrations folder is full of zips but I wonder if ids is looking for the vbf file.
May well be calling you soon for an appointment
martynx wrote:Cool & nope we dont get to see the counter values.. only way to potentially discover them would be to read the BCM's 912MCU before & after resetting them. No counter specific DTC is set either so its a case of having a late-ish cal in place that supports the counter reset procedure & resetting them whenever the PRV is replaced. The counters have a crucial input to fueling calculations..
& as Loot says, (assuming no physical problem with the injectors) its a case of tricking the system into doing both learns by doing the service functions on the wrong order or doing from cold or from hot etc.. Once you have done both successfully , you should then be able to redo them in the right order..
