Hi Guys,
Been a lurker on the forums for a while.
Just been attempting to do the front disks on my mk6 rwd chassis cab.
It was a twat of a job and the van is still in the yard on stands, the brake disk had dintegrated and some of the 5 13 mm nuts snapped on the way out so had to hammer of the hub and get them out in the vice which took ages.
I was following this guide by guy 88: viewtopic.php?f=18&t=32015
I have got a little confused as mine seems to be somewhat different the t50 torx are not actually screwed into the disk and it is just held on with 5 13mm bolts is that how its supposed to be.
The half shaft dropped out easy enough along with bearing on the back out and i was wondering does it just push back in will it all tighten up nice and tight?
Look forward to your thoughts could illustrate my post with pictures tomorrow if reqd.
