Era Block Lock - additional rear door security
Postby 4133kyle » Fri Apr 25, 2014 11:42 pm
Following on from my recent concern over leaving my van In Barcelona and fitting a large and advertising additional rear door lock I suddenly remembered about Era Block Locks from my Landrover rebuild.
Anyway bought one and fitted it today.
Took a few quick pics as I fitted it as they may be helpful to someone.
Essentially the lock is a two part external 'block' that attaches from inside the rear door so you dont have to drill any external holes in the panelwork - you don't need to drill any internally but I modified its fitting slightly.
I pulled the seal off the door and fitted the lock underneath but trimmed the metal 'gripper' section from the seal where it fits around the lock, this still allows a weather proof seal and gives a lower profile to the lock so it doesn't foul the closing door.
The instructions say to use the included screws to 'jack' the lock in position but I drilled the inside of the rear door and fitted 'riv-nuts' to screw the lock bracket into. There are two more screws needed so the lock cant be pried away from the door 'to get behind it' but I need get some correct length screws rather than the overly long supplied screws or I might weld a steel plate/block to the inside of the bracket.
Result seems pretty secure and will protect against 'Tibbe' double unlocking. Time will tell. The lock was £26 from Ebay.
Fitting instructions.
http://www.era-security.com/media/downl ... 821231.pdf
ImageWP_20140425_001 by Lara_Look_Fabulous, on Flickr
ImageWP_20140425_010 by Lara_Look_Fabulous, on Flickr
ImageWP_20140425_003 by Lara_Look_Fabulous, on Flickr
ImageWP_20140425_007 by Lara_Look_Fabulous, on Flickr
4133kyle
Re: Era Block Lock - additional rear door security
Postby v8dave » Sat Apr 26, 2014 12:16 am
If someone wants into your van that will only advertise the fact that your protecting something.
Does the criminal care about damage ?
Will any thing you fit slow down someone with a crowbar or a disc cutter ?
The current generation of cordless angle grinders are impressive bits of kit.
I've not read the other thread but what about the side door ?
mk7 08reg 2.4 T350 LWB MHR RWD
mk6 X reg 2.4 T350 LWB MHR RWD - scrapped
mk4 J reg 2.5 L300 LWB MHR RWD - sold on
Notice a trend there ? not too big and not too small
v8dave
Postby Herts » Sat Apr 26, 2014 7:32 am
Good work Kyle, any extra lock helps with security. Most crimes are done by opportunist.
Andy
MK7 - 2.4 RWD/HR/LWB 3.5T 140HP (BIG BOYS TOY!)
Number 1 Emergency Call out Engineer!!!
http://www.hertsplumbinganddrainage.co.uk
Herts
Postby bigjohnthomas » Sat Apr 26, 2014 8:12 am
I don't know if you have ever tried to break in to a transito ?
But if you've not got a funny key :wink:
You certainly wouldn't bother trying to force the door locks
they just won't budge
I just bent my jimmi bar
viewtopic.php?f=5&t=97570
bigjohnthomas
Postby invernessguy » Sun Apr 27, 2014 6:52 pm
As a locksmith, with a little bit of inside knowledge of how secure a transit is... Thats not going to stop anybody.
A theif will take one look at it and will attempt entry from another door. There are several easy (and quiet) ways into a mk6 and 7 van. They dont take much time either.
The drivers door lock is vulnerable, as it is very easily picked.
The central locking is vulnerable through a simple trick.
Once the van is unlocked, the side loading door will open, and anything in the back can be got at.
Best advice is park it somewhere secure and well lit, preferrably with cctv.
Now located in Stirling!
invernessguy
Postby invernessguy » Sun Apr 27, 2014 6:55 pm
Oh yes...
I hadnt seen that type of lock before, but its just a standard 5 pin cylinder... That wouldnt take long to open either!
Security is all about deterring theives, but there is nothing there that woud stop them if your van looked attractive.
invernessguy
Postby mjsroofing » Sun Apr 27, 2014 8:32 pm
I can get in that lock in 3p seconds.
www.mjsroofing.co.uk
2022 2.0 ecoblue fwd, 72k
2009 2.2 tdci 115ps just over 110k now.
2002 2.0 tddi 100ps. Over 205k still sweet . Now owned by Jay.
2001 escort van 75, 1.8 turbo intercooler. scrapyard heaven
1995 escort van 50, 1.8 straight diesel, scrapyard heaven.
mjsroofing
Postby 4133kyle » Sun Apr 27, 2014 8:43 pm
The van is a welfare with a 2nd internal bulkhead so if the side door is opened via a Tibbe key and double unlocking the drivers door then they still cant access the rear load/cargo area. They could make a brew though!
I wanted something discreet that would deter or help protect our camping/personal belongings when the van isn't on a camp site. Its now painted white so blends in better. The other option was to fit an Abus locking plate thing that I have lying around ;
http://www.tooled-up.com/product/abus-1 ... wwodZCkAnQ
but I thought this shouted 'valuables on board a little too much.
I have a clutchclaw (borrowed from my Landrover) to help protect the van from being stolen.
4133kyle
Postby mjsroofing » Sun Apr 27, 2014 8:51 pm
I will put some theifs off I suppose.
mjsroofing
Postby invernessguy » Sun Apr 27, 2014 11:47 pm
Best to get a door wiring protector plate. Thats hidden, and will help ptotect against a common entry point.
And weld you valuables to the floor!
invernessguy
Postby mjsroofing » Mon Apr 28, 2014 9:51 pm
Maybe get a dog.
mjsroofing
