vcm2 module programming
Postby cyrus883 » Fri Jun 13, 2014 8:36 pm
Hi all ive just got a vcm2 with ids to programe my pump 2.4 tddi and when i click to go to module programming it says selection not available im just wondering if anyone knows how to get this working i did look on net and found this http://blogs.permoveo.ltd.uk/2012/02/02 ... available/ but could not find _to_flag.exml file to delete so guess thats a waste of time then :roll: lol thanks all steve
cyrus883
Re: vcm2 module programming
Postby blue estate » Fri Jun 13, 2014 8:39 pm
speak to loot you need the extended programing module patch :wink:
72plt MG 5 ev estate Battery car
blue estate
Postby loot » Fri Jun 13, 2014 10:58 pm
Pm me your hotmail and I'll send it to you :wink:
Ids map here
loot
Postby sand010 » Fri Aug 29, 2014 8:57 am
I too am having this problem. I installed an exteneded programme patch on my desktop. Restarted ids then went into the toolbox icon in IDS (v.86) selected module programming -selection not available??:/
rekon it's a duff patch??
Loot can i try yours?
sand010
Postby loot » Fri Aug 29, 2014 9:17 am
Course you can, send me your email by pm and I'll send it to you.
Just extract it to desktop and run it.
Is your ids working on other things, is it licenced correctly? :-)
Ids map here
loot
Postby mjsroofing » Fri Aug 29, 2014 11:48 am
Loot is the man for this,
www.mjsroofing.co.uk
2009 2.2 tdci 115ps just over 51k and sweet as a nut ( so far )
2002 2.0 tddi 100ps. Over 205k still sweet . Now owned by Jay.
2001 escort van 75, 1.8 turbo intercooler. scrapyard heaven
1995 escort van 50, 1.8 straight diesel, scrapyard heaven.
mjsroofing
Postby Bowtay » Wed Jan 17, 2018 1:20 pm
Hi I'm having problems module programming selection not available can you help
Sent from my SM-G930F using Tapatalk
Bowtay
Postby loot » Wed Jan 17, 2018 2:22 pm
Download, extract, run this :arrow:
Don't click the middle link click the top right link to download and in the dialogue box that pops up select direct download :idea:
https://www.dropbox.com/sh/kuej4nq5vljb ... g.zip?dl=0
Ids map here
loot
Postby knobby1 » Wed Jan 17, 2018 7:15 pm
Just remember guys, "some" of the clone IDS VCM-II units just don't work, many of them just don't have the internal gubbins for them to work as they should, they can read and erase codes etc but when it comes to some module programing functions etc...they often fall a bit short.
We've found it to be a bit of a lottery. Try to make sure you get the "SP-177-C1" unit, this will give you the best chance of getting a working unit. Loot and I (and many others) have been burnt by these things before.
Forscan and a ELM-327 seems to be a lot more user friendly these days.
Postby Bowtay » Wed Jan 17, 2018 10:32 pm
Managed to sort my problem it had 2013 in the reg file changed it to current date and wham iv just took the speed limiter off a transit thanks guys
Bowtay
Postby Bowtay » Sat Apr 14, 2018 7:28 am
my ids won't remove the speed limiter off a 2016 connect and it wont upload config we took the van to ford they removed it no problem does anyone know if the clone ids can remove a 2016 connect speed limiter I have a good quality clone
Bowtay
